I'm brand new to Nagios so forgive me if this is a silly question.
I added a few network switches yesterday and today I went into the Core Configuration Manager and changed the host names. Doing this reset all of the performance graphs. Is that normal behavior? Or is there a way to change the host names without losing the historical performance graph?
Thanks!
Monitoring host name change resets performance graphs
Re: Monitoring host name change resets performance graphs
Yes this is. If you would like to retain performance data you would need to use the "Renaming Tool" under Configure -> CCM -> "Renaming Tool"
Scott,
Thanks for the reply. I didn't know that tool was there so I will use it from now on. Thanks!
