installation nagios on snow leopard error: make[2]: *** [ins
qafro
Post by qafro »
I've downloaded and Extract the Nagios source code tarball on my macosx ,snow leopard
eg
cd ~/downloads
tar xzf nagios 3.4.1.tar.gz
cd nagios 3.4.1
I created a group = nagios via macosx system preferences
Ran ./configure --with-command-group=nagios
Then I ran
make install but I get an error msg
make install
cd ./base && make install
make install-basic
/usr/bin/install -c -m 775 -o nagios -g nagios -d /usr/local/nagios/bin
install: nagios: Invalid argument
make[2]: *** [install-basic] Error 67
make[1]: *** [install] Error 2
make: *** [install] Error 2
Any ideas of fix on macosx cmd?
agriffin
Re: installation nagios on snow leopard error: make[2]: ***
Post by agriffin »
Are you following any instructions somewhere? It's a few years old, but I found this guide to installing Nagios on Mac OS X.
qafro
Post by qafro »
thank
Post by slansing »
Let us know if that worked for you and you were able to get off the ground.
qafro
Post by qafro »
I've looked at the blog but its a bit confusing.
No step by step guide
Any help needed?
