Information about license status ( Win Srv 2008 )
Bogdan_B
Post by Bogdan_B »
Can you tell me if it is possible to pull somehow in Nagios the information about time remaining ? ( like as below image )
Cheers,
bb
Re: Information about license status ( Win Srv 2008 )
You can get that line from running the following
cscript //NoLogo c:\windows\system32\slmgr.vbs -dli|find "Time Remaining"
You can create a command with that line in NSClient++ to return the data to Nagios.
This isn't going to do any checking on if it is expired, you would have to write a file script to parse that data if you wanted to do that.
Bogdan_B
Post by Bogdan_B »
So,
I created the command in NSClient++ file. There are two more commands functioning correctly.
The script should return "Licensed" but it returns "Error: product key not found."
Bogdan_B
Post by Bogdan_B »
All settings below :
Can you post the output of running this from the windows command line
and
Bogdan_B
Post by Bogdan_B »
No output for last command.
Bogdan_B
Post by Bogdan_B »
I tried below command :
cscript //NoLogo c:\windows\system32\slmgr.vbs -dli|find "License Status"
which returns
Nagios output is "Unrecognized option: -dli ".
Ok, we did some work on this for you and here is what we came up with:
Create a file license.bat in C:\Program Files\NSClient++\scripts with the following contents
@echo off
cscript //NoLogo c:\windows\system32\slmgr.vbs -dli | find "Time Remaining"
Change your NSC.ini to be
check_license=scripts\license.bat
restart NSClient++ service
Bogdan_B
Post by Bogdan_B »
It is OK now.
Thank you !
Awesome.
Glad you got it working.
