CPU and RAM metrics
healthfusion
CPU and RAM metrics
Post by healthfusion »
I am having some issue with metrics addon.
It doesn't display anything for CPU or Memory Usage. Disk Usage, Load and Swap are working. When I click CPU Usage or Memory Usage message "No matching data to display".
I monitor Windows and Linux hosts for Windows through WMI and Linux through NRPE agent.
Do I need to monitor in different way?
Thanks for your help!
Re: CPU and RAM metrics
Unfortunately the metrics component is VERY particular. You must be using the Windows Agent and it will show CPU for Windows.
