Result History for check_snmp
Is there any way to graph/pull a history of data obtained through the check_snmp group of plug-ins? We are pulling in processor and memory data per process but don't have any way to graph it or look at historical data.
Re: Result History for check_snmp
What specific plugin are you referring to? I some of them you need to add the -f flag to get performance data
check_snmp_process_wizard.pl and check_snmp_process.pl
I checked the arguments in CCM and we are using the -f flag.
both of these also required the addition of -F (capital F)
I added in the -F but I still don't have performance metrics. The error message states "No performance graphs were found for this service".
Can you show us the actual command that you are running in the command line and the output of it? (Hide the sensitive data).
