If I do "tail /var/spool/mail/root" I usually see the following:
2012-12-13 08:39:22: ERROR: Target[10.236.5.1_1][_OUT_] ' $target->[494]{$mode} ' did not eval into defined data
2012-12-13 08:39:22: ERROR: Target[10.236.5.1_3][_IN_] ' $target->[495]{$mode} ' did not eval into defined data
2012-12-13 08:39:22: ERROR: Target[10.236.5.1_3][_OUT_] ' $target->[495]{$mode} ' did not eval into defined data
2012-12-13 08:39:22: ERROR: Target[10.236.5.1_4][_IN_] ' $target->[496]{$mode} ' did not eval into defined data
2012-12-13 08:39:22: ERROR: Target[10.236.5.1_4][_OUT_] ' $target->[496]{$mode} ' did not eval into defined data
2012-12-13 08:39:22: ERROR: Target[10.246.151.1_1][_IN_] ' $target->[936]{$mode} ' did not eval into defined data
2012-12-13 08:39:22: ERROR: Target[10.246.151.1_1][_OUT_] ' $target->[936]{$mode} ' did not eval into defined data
2012-12-13 08:39:22: ERROR: Target[10.246.151.1_2][_IN_] ' $target->[937]{$mode} ' did not eval into defined data
2012-12-13 08:39:22: ERROR: Target[10.246.151.1_2][_OUT_] ' $target->[937]{$mode} ' did not eval into defined dataI transferred this to my PC tried opening this from a couple of different programs but it is way too big.
I deleted the file and it was recreated pretty quickly. I will send a copy of this file to the support email address as it contains sensative information.
1) How do I resolve the issue that is occurring? I'm not particuarly fond of having log files that grow massively in size.
2) As a suggestion, perhaps XI should come with a localhost check that identifies the size of /var/spool/mail/root and alarms when it reaches a certain size.
Nagios XI 2012R1.2 VM CentOS 32bit on ESXi 5.0 Update 1.
