HostEscalation Issue
jenglee
Post by jenglee »
I am trying to use hostescalation to limit the number of emails that I receive.
When I define hostescalation with the below, I get an email every min. If I comment the notification out
in the service-templete definition I get no emails.
I have a file called host_notification_escalation.cfg which contains
define hostescalation{
host_name hostname
first_notification 1
last_notification 2
notification_interval 1
contact_groups admin
Then I have the host defined in a conf file call windows.cfg
use template
host_name hostname
alias hostname
address ipaddress
parents a, b
icon_image
vrml_image
statusmap_image
use service-template
host_name hostname
service_description description
check_command check_wmi_mem!10%!20% ## Lowered these numbers to invoke nagios to send critical emails
name service-template ;
active_checks_enabled 1 ;
passive_checks_enabled 1 ;
parallelize_check 1 ;
obsess_over_service 1 ;
check_freshness 0 ;
notifications_enabled 1 ;
event_handler_enabled 1 ;
flap_detection_enabled 1 ;
failure_prediction_enabled 1 ;
process_perf_data 1 ;
retain_status_information 1 ;
retain_nonstatus_information 1 ;
is_volatile 0 ;
check_period 24x7 ;
max_check_attempts 4 ;
normal_check_interval 1 ;
retry_check_interval 1 ;
contact_groups admins ;
notification_options u,c,r ;
notification_period no-nights ;
register 0 ;
Re: HostEscalation Issue
Post by slansing »
That is correct, are you trying to receive emails every one minute? Because that is how it is setup:
jenglee
Post by jenglee »
The issues is that I don't want to receive emails every minutes. I want to receive two email one minutes apart from each other.
sreinhardt
-fno-stack-protector
Post by sreinhardt »
The notification_interval 1 setting should cause emails to be sent every 1 minute, for each object that this is set for. If you are wanting to have two people receive emails, simply set them both as contacts. Otherwise as you mentioned in the first post, if you wish to limit the time between emails, you may want to set the interval to a larger number. If that is not what you are looking for, could you provide more detail as to how you wish this to work.
