Operations Screen - HTTPS
Gavin
Post by Gavin »
We have just deployed Nagios XI 2012R1.3 (clean install) and are having some troubles getting the 'Operations Screen' to work over HTTPS.
We're currently using a self-signed certificate, and followed this guide to the letter: http://assets.nagios.com/downloads/nagi ... ios_XI.pdf.
The only additional change I made was to add an Apache Rewrite from HTTP to HTTPS. Everything works perfectly, apart from Operations Screen which just loads blank via. HTTPS (notably, the counter doesn't do anything either):
https://www.evernote.com/shard/s89/sh/2 ... 021:24.jpg
If I disable the rewrite, and load the page via. HTTP, it works perfectly.
Does anyone have any idea what might be causing this? I've uninstalled / reinstalled the component to no avail.
Many thanks,
Gavin
Gavin
Re: Operations Screen - HTTPS
Post by Gavin »
Wow, this has been bugging me for ages, and within seconds of posting on the forum I've found the problem!
When the page loads, it brings in 'jquery.min.js' from Google via. HTTP. I imagine that my browser refused to run this because it was 'insecure'. I've amended 'opscreen.php' so it loads this via. HTTPS, and it worked straight away:
Before:
<script type="text/javascript" src="http://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js">
After:
<script type="text/javascript" src="https://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js">
Gavin
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Thanks for posting your answer Gavin! Hopefully someone else can find this useful as well!
you could also make it
<script type="text/javascript" src="/nagiosxi/includes/js/jquery/jquery-1.8.2.min.js">
        </script>
and not load from google directly...
