Nagios XI Operations Screen Component 1.2 does not display i
TBT
Post by TBT »
As outlined in ticket:http://tracker.nagios.com/view.php?id=341
Chrome Version 24.0.1312.52 m
Nagios XI 2024R2.2.1 (8 Servers)
Nagios Fusion 2024R1.0.2
Re: Nagios XI Operations Screen Component 1.2 does not displ
Post by slansing »
This has been tested with the latest version of Google Chrome and Ops Screen 1.2, we were unable to reproduce your bug, have you verified that your logs are not showing anything odd?:
tail -f /var/log/httpd/error_log
Attempt to access after you have the running tail up.
We will continue to take a look at this and keep you apprised.
TBT
Post by TBT »
One error present. I'd expect this image would be included in the package, but it's not included the zip. Therefore not an isolated issue, it's the release.
 File does not exist: /usr/local/nagiosxi/html/includes/components/opscreen/throbber.gif
Here is a new component with the reference to that file fixed. However it shouldn't prevent it from loading in any browser.
TBT
Post by TBT »
Please verify you are using Google Chrome (http://www.google.com/chrome), not Chromium (Open source fork) .
That 1.3 update introduced the following errors:
[Thu Jan 17 10:29:37 2013] [error] [client IP] PHP Notice:  Undefined index: fieldmap in /usr/local/nagiosxi/html/includes/dbauth.inc.php on line 368, referer: https://127.0.0.1:28191/nagiosxi/includes/components/opscreen/opscreen.php
[Thu Jan 17 10:29:37 2013] [error] [client IP] PHP Warning:  array_key_exists() expects parameter 2 to be array, null given in /usr/local/nagiosxi/html/includes/dbauth.inc.php on line 368, referer: https://127.0.0.1:28191/nagiosxi/includes/components/opscreen/opscreen.php
I don't get any error like you do, but I did notice that you are running on https and the component was calling the jquery library from
http://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js
Attached is another modded version calling from
https://ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js
TBT
Post by TBT »
Damn, should have known better. Yes, Chrome will not load insecure pages in iframe. I've confirmed switching that Google URL to https was the fix.
However, those errors are still present in the log.
abrist
Red Shirt
Post by abrist »
Good to hear one of your problems are resolved. The devs down here are working on a potential bug or 2 in opscreen, stay tuned.
