rrdcached socket permission
Mitchell
Post by Mitchell »
with default installation the permission for rrdcached socket were set to 755 even if -l -s -m options are passed correctly to rrdcached.
This was creating issue with showing graphs with latest pnp4nagios web interface which required 660 minimun.
The reason is the order of the options passed to rrdcached.
by the script listed in http://assets.nagios.com/downloads/nagi ... ios_XI.pdf
The correct order for options should be -s -m -l
the following line in the script needs to be updated with correct order
cat >/etc/sysconfig/rrdcached <<-EOF
        OPTIONS="-l unix:/var/rrdtool/rrdcached/rrdcached.sock -F -s nagios -m 0660 -w 900 -z 90 -j /var/nagiosramdisk/tmp/ -b /var/rrdtool/rrdcached -P FLUSH,PENDING"
should be
        OPTIONS="-s nagios -m 0660 -l unix:/var/rrdtool/rrdcached/rrdcached.sock -F -w 900 -z 90 -j /var/nagiosramdisk/tmp/ -b /var/rrdtool/rrdcached -P FLUSH,PENDING"
Ashish
Re: rrdcached socket permission
Confirmed and patched!
Thanks!
