Firebox Configuration
Does anyone know what steps to take to get the firebox to talk to the Nagios server? Im running 3.2.2 and my firebox is a X750e running on Firmware ver 11.1.3
Re: Firebox Configuration
I am using the bare defaults under <<<setup<<<<smtp
Using ver 1/2 snmp
my community string is blank
I get the below errors
Port 1 Bandwidth Usage
UNKNOWN 09-16-2010 10:48:01 12d 18h 17m 36s 3/3 check_mrtgtraf: Unable to open MRTG log file
Port 1 Link Status
CRITICAL 09-16-2010 10:44:03 12d 18h 16m 11s 3/3 (Return code of 127 is out of bounds - plugin may be missing)
Uptime
CRITICAL 09-16-2010 10:43:01 12d 18h 14m 46s 3/3 (Return code of 127 is out of bounds - plugin may be missing)
Using ver 1/2 snmp
Port 1 Link Status
Uptime
