Could you please explain me why it happened this NRPE error ?
Thank you !
bb
check_nrpe error
check_nrpe error
Re: check_nrpe error
Is NRPE running on the External IP?
Is there any firewall between the XI server and the External IP?
On the External IP, can you run
iptables -L
On Xi server :
NRPE is running on the external IP only for Windows OS. When I try it for Linux I received : CHECK_NRPE: Socket timeout after 10 seconds.Is NRPE running on the External IP?
Yes but it is working fine between the XI server and Win OS.Is there any firewall between the XI server and the External IP?
There is vmware ESXi 4.1 and it doesnt have iptables.On the External IP, can you run: iptables -L
On Xi server :
[root@SERVER ~]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere state RELATED,ESTAB LISHED
ACCEPT icmp -- anywhere anywhere
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:s mtp
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:h ttps
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:s sh
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:s nmp
ACCEPT udp -- anywhere anywhere state NEW udp dpt:s nmp
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:s nmptrap
ACCEPT udp -- anywhere anywhere state NEW udp dpt:s nmptrap
ACCEPT tcp -- anywhere anywhere state NEW tcp dpts: nrpe:nsca
REJECT all -- anywhere anywhere reject-with icmp-ho st-prohibited
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Your configuration will be different between Linux and Windows NRPE agents, are you attempting to install and monitor an ESX server with NRPE?
Yes. Is it possible ?slansing wrote:Your configuration will be different between Linux and Windows NRPE agents, are you attempting to install and monitor an ESX server with NRPE?
Theoretically yes, you would need to compile it on the underlying OS, the procedure would depend on the OSBogdan_B wrote:Yes. Is it possible ?
Did you follow our documentation for installing the linux agent (nrpe) on the client machine?
Can you telnet to your client from your Nagios XI server?
If you have nc installed on the Nagios XI server, you can also run:
telnet <client_IP> 5666
nc -zv <client_IP> 5666
