NRPE client on nagiosxi server
We want to monitor the disk space and the number of files in the checkresults dir of a nagiosxi server from another nagiosxi server.
It seems we need NRPE client on the monitored nagiosxi server but one is not properly configured. We updated the nrpe.cfg and xinet.d/nrpe allow_from servers.
Looks like the server is not listening on port 5666.
Re: NRPE client on nagiosxi server
Please see below. Looks to me like NRPE is enabled
[root@nagiosxi2-uk ~]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT icmp -- anywhere anywhere
ACCEPT tcp -- anywhere anywhere tcp dpt:nrpe state NEW
ACCEPT tcp -- anywhere anywhere tcp dpt:6557 state NEW
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:ssh
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:http
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:https
REJECT all -- anywhere anywhere reject-with icmp-host-prohibited
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
mroter,
can you verify that port 5666 is accepting requets
also, what response do your receive when you run check_nrpe against the client machine?
-Yancy
netstat -a | grep 'LISTEN'
/usr/local/nagios/libexec/check_nrpe -H xx.xx.xx.xx
-Yancy
The "client" machine is a Nagios XI server in this case.
Looks like the server is NOT listening on port 5666. Probably a configuration issue. Please advise.[root@nagiosxi2-uk ~]# netstat -a | grep 'LISTEN'
tcp 0 0 *:mysql *:* LISTEN
tcp 0 0 localhost:oa-system *:* LISTEN
tcp 0 0 *:ssh *:* LISTEN
tcp 0 0 localhost:postgres *:* LISTEN
tcp 0 0 localhost:smtp *:* LISTEN
tcp 0 0 *:http *:* LISTEN
tcp 0 0 *:https *:* LISTEN
tcp 0 0 *:nsca *:* LISTEN
unix 2 [ ACC ] STREAM LISTENING 6789 @/com/ubuntu/upstart
unix 2 [ ACC ] STREAM LISTENING 9556 /usr/local/nagios/var/ndo.sock
unix 2 [ ACC ] STREAM LISTENING 9041 private/bounce
unix 2 [ ACC ] STREAM LISTENING 9045 private/defer
unix 2 [ ACC ] STREAM LISTENING 9049 private/trace
unix 2 [ ACC ] STREAM LISTENING 9053 private/verify
unix 2 [ ACC ] STREAM LISTENING 9057 public/flush
unix 2 [ ACC ] STREAM LISTENING 9061 private/proxymap
unix 2 [ ACC ] STREAM LISTENING 9065 private/proxywrite
unix 2 [ ACC ] STREAM LISTENING 9069 private/smtp
unix 2 [ ACC ] STREAM LISTENING 9073 private/relay
unix 2 [ ACC ] STREAM LISTENING 9077 public/showq
unix 2 [ ACC ] STREAM LISTENING 9081 private/error
unix 2 [ ACC ] STREAM LISTENING 9085 private/retry
unix 2 [ ACC ] STREAM LISTENING 9089 private/discard
unix 2 [ ACC ] STREAM LISTENING 9093 private/local
unix 2 [ ACC ] STREAM LISTENING 9097 private/virtual
unix 2 [ ACC ] STREAM LISTENING 9101 private/lmtp
unix 2 [ ACC ] STREAM LISTENING 9105 private/anvil
unix 2 [ ACC ] STREAM LISTENING 9109 private/scache
unix 2 [ ACC ] STREAM LISTENING 8715 /var/lib/mysql/mysql.sock
unix 2 [ ACC ] STREAM LISTENING 633384 /tmp/.s.PGSQL.5432
unix 2 [ ACC ] STREAM LISTENING 9026 public/cleanup
unix 2 [ ACC ] STREAM LISTENING 10358941 /usr/local/nagios/var/rw/live
unix 2 [ ACC ] STREAM LISTENING 9033 private/tlsmgr
unix 2 [ ACC ] STREAM LISTENING 9037 private/rewrite
try
If it doesn't come up I would take a look at the syslog while running the command above again
service xinetd restart
tail -f /var/log/messages
I reverted my changes to nrpe.cfg and /etc/xinet.d/nrpe and retsrted inet.d
I now can see nrpe running/etc/init.d/xinetd restart
When trying to connect from remote server I get:[root@localhost ~]# netstat -a | grep 'LISTEN'
tcp 0 0 *:nrpe *:* LISTEN
In the syslog I found:os/libexec/check_nrpe -H 172.20.1.71
Connection refused or timed out
Feb 4 18:31:20 localhost xinetd[27388]: Exiting...
Feb 4 18:31:20 localhost xinetd[29278]: IPv6 socket creation failed for service nrpe, trying IPv4
Feb 4 18:31:20 localhost xinetd[29278]: IPv6 socket creation failed for service nsca, trying IPv4
Feb 4 18:31:20 localhost xinetd[29278]: xinetd Version 2.3.14 started with libwrap loadavg labeled-networking options compiled in.
Feb 4 18:31:20 localhost xinetd[29278]: Started working: 2 available services
On the client machine (172.20.1.71), open the nrpe file and see if the Nagios XI IP address is added to the "only_from = " line.
If it is not listed, add it. For example:
and restart the daemon:
Try your check again from the Nagios XI server (libexec directory):
Make sure you can connect to port 5666. From your XI machine, try running:
or if you have nc installed, you can try:
vi /etc/xinetd.d/nrpe
only_from = 127.0.0.1 192.168.0.100
./check_nrpe -H 172.20.1.71
telnet 172.20.1.71 5666
nc -zv 172.20.1.71 5666
I followed the steps but it is still not working
From the server itself (172.20.1.71) I get:
From the remote server (172.20.1.106) I get:
In the messages log I get:[root@localhost ~]# telnet 172.20.1.71 5666
Trying 172.20.1.71...
Connected to 172.20.1.71.
Escape character is '^]'.
Connection closed by foreign host.
Feb 5 08:31:02 localhost xinetd[18178]: START: nrpe pid=18924 from=172.20.1.71
Feb 5 08:31:02 localhost xinetd[18924]: FAIL: nrpe address from=172.20.1.71
Feb 5 08:31:02 localhost xinetd[18178]: EXIT: nrpe status=0 pid=18924 duration=0(sec)
[root@localhost libexec]# telnet 172.20.1.71 5666
telnet: connect to address 172.20.1.71: No route to host
mroter,
What does xinetd file look like?
if your using xinetd to accept connections, your xinetd file should look something like this:
also, add the following to /etc/services
-Yancy
# default: on
# description: NRPE
service nrpe {
flags = REUSE
socket_type = stream
wait = no
user = nagios
server = /usr/local/nagios/libexec/nrpe
server_args = -c /usr/local/nagios/libexec/nrpe.cfg --inetd
log_on_failure += USERID
disable = no
# Change this to your primary Nagios server
nrpe 5666/tcp # NRPE
