I have recently upgraded the version into Nagios XI 2012R1.5, after that i tried to login in the CCM. I am getting blank page, however i can able to see the configuration in Legacy CCM ( i have enclosed screenshot in the thread). Earlier version of 1.4 was worked with option, this latest having this issue. Let me know if any settings needs to be configured. Thanks!!
Regards,
Raj.
Blank page on CCM in Nagios XI 2012R1.5
gm_rajkumar
Re: Blank page on CCM in Nagios XI 2012R1.5
Could you please run the following from the command line while trying to access the new CCM and report any errors, thanks
tail -f /var/log/httpd/error_log-
gm_rajkumar
I've found some of errors, please look into this. thanks in advance!!
Regards,
Raj.
Regards,
Raj.
Can you run the following and report the output
It should be like this
ls -l /usr/local/nagiosxi/etc/components/ccm_config.inc.phpCode: Select all
-rw-r--r-- 1 apache nagios 568 Feb 4 09:11 /usr/local/nagiosxi/etc/components/ccm_config.inc.php-
gm_rajkumar
I have found the solution for this, there is no such file exists. I have created it my own. After that it started works, please clear this bug, thanks!!
Regards,
Raj.
Regards,
Raj.
I'm glad it's fixed now. Thanks for the feedback!
