Monitoring Windows server 2003 using SNMP wizard & found below problem for CPU Usage & D:\ Drive
CPU usage showing critical & (Return code of 126 is out of bounds plugin may not be executalbe)
D:\ drive disk usage showing Unknown Usage check _snmp -H <IP Address > -o OID -w warn_range -c crit_range.
Not able to monitor CPU & D drive using snmp
lafargeuser
Re: Not able to monitor CPU & D drive using snmp
Lets run the following from the command line
chmod +x /usr/local/nagios/libexec/check_snmp*-
lafargeuser
Thanks. Its done.
