Error when trying to Monitor TomCat6
PCrossan
Post by PCrossan »
Hi All,
We now have Nagios setup in our environment :)
Unfortunately we have 1 issue at the moment, when monitoring TomCat6 we receive the following error "You need root privileges to run this script"
We do not want to give the Nagios account root permissions - Does anyone know why it requires root permissions for this check?
thanks for your help
Re: Error when trying to Monitor TomCat6
Post by slansing »
If it is an executable just make sure that the user account can execute it, in most cases a simple:
chmod +x /usr/local/nagios/libexec/custompluginnamehere
Will do the trick, or wherever you have the plugin located. Also, welcome to the community!
