Hello
The issue is I tried upgrading Nagios. I backed it up, and upgraded following this: http://assets.nagios.com/downloads/nagi ... ctions.pdf
Everything went swimmingly until I logged back in and it says I still need to update, but to an older version, see below:
A new Nagios XI update is available.
2012R1.5 was released on January 30th, 2013.
Visit http://www.nagios.com to obtain the latest update.
Latest Available Version: 2012R1.5
Installed Version: 2012R1.6
Last Update Check: 07/02/2013 11:46:39
Update showing older than installed one
Re: Update showing older than installed one
After you upgraded, when you logged back into XI, were you presented with a button labeled "Finish Upgrade"? If not, try logging out(Hitting logout, not just closing browser) and then login again and see if it comes up.
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Yes, it came up with 'Finish Update' then 'Continue' and it was on R1.3 so it has upgraded.
Just checked mine, shows 1.5 available and 1.6 installed. Mike must not have updated the backend yet. Lets blame Mike
It shouldn't cause us any issue.
Correct, just got another report of this, I will let him know when he gets in this morning.. thanks guys!
