When I select Service Status page (for instance) en then press the NEXT button I get a 404 not found
The url under that NEXT button:
http://testmachine/nagiosxi/includes/co ... ces&page=1
Anyone an idea?
Interface issue
Re: Interface issue
Hmm found in tracker that this seemed to be a bug that has been fixed.
Re: Interface issue
Yeah this is a known bug that will be fixed in the next update, but in the meantime you can make the change in the PHP by following the instructions on the bug tracker.
http://tracker.nagios.com/view.php?id=87
