Check Iperf
rbaholding
Check Iperf
Post by rbaholding »
I'm using check_iperf plugin. Is there a posibility of performance graphs for this plugin?
Regards
Re: Check Iperf
Post by slansing »
It looks like a user beat you to the chase, on the comments section of the exchange page someone notes that it only need performance data and it would be perfect. I suggest you email the creator and see if they can add that functionality in since it is sought after! His address is located within the script.
Original plugin: http://exchange.nagios.org/directory/Pl ... rf/details
rbaholding
Re: Check Iperf
I try to write to plugin creator but impossible. Can you tell me if is there any other way to generate graphs, please?
Thanks and regards
Re: Check Iperf
Post by slansing »
Without the ability already built into the plugin no, there is no way it would know what to pull. What do you mean by it is impossible to contact the creator of the plugin?
rbaholding
Re: Check Iperf
I try to send an email but error:
julien.touche@touche.fr.st>: Relay access denied
Regards
Re: Check Iperf
Post by slansing »
That is most likely because your MTA is not configured to send to outside addresses like that. You may need to talk to your mail admins or send a personal email.
rbaholding
Re: Check Iperf
Same problem from GMail.
abrist
Red Shirt
Re: Check Iperf
Post by abrist »
From the comments on the exchange:
Only needs performance output for graphing and it would be perfect. Perfomance output can be easily added by putting a "| bd=$speed" to the output string. Thanks for the script.
Have you tried adding "| bd=$speed" to the print outputs?
if ($connect_ok == 0) {
	print "NOK: iperf didn't connect to '$target'.\n"; $exit = 2;
} elsif ($speed<$mincrit) {
	print "Critical: iperf speed of '$target': $speed ($unit) < $mincrit. | bd=$speed\n";$exit=2;
} elsif (defined($maxcrit) && $speed > $maxcrit) {
	print "Critical: iperf speed of '$target': $speed ($unit) > $maxcrit. | bd=$speed \n";$exit=2;
} elsif ($speed < $minwarn) {
	print "Warning: iperf speed of '$target': $speed ($unit) < $minwarn. | bd=$speed \n";$exit=1;
} elsif (defined($maxwarn) && $speed > $maxwarn) {
	print "Warning: iperf speed of '$target': $speed ($unit) > $maxwarn. | bd=$speed \n";$exit=2;
} else {
	print "OK: iperf returns $speed $unit (wsize $mtu). | bd=$speed \n"; $exit = 0;
rbaholding
Re: Check Iperf
Thank you very much. It works perfectly!!
I didn't understand where to put the text "| bd=$speed"
Regards
Re: Check Iperf
Post by slansing »
Great! Thanks for letting us know.. in the future many common requests have already been added into plugins like we found with this one. Though the creator may not include it.
