World Time Clock dashlet not displaying the time
cskang
Post by cskang »
I have created a dashboard called, testDash under Dashboards top menu.
And I went to 'Available Dashlets' link and found 'World Time Clock' dashlet.
I tried to add 'World Time Clock' into testDash just created.
But, only empty frame is shown on testDash, but no image of the clock is displayed.
I had this above problem in my instance of NagiosXI.
So, I decided to try it out on NagiosXI demo site. I am finding the same result.
I have ran this with FireFox version 19.0
- with add-on Shockwave Flash 11.6.602.168
Re: World Time Clock dashlet not displaying the time
Interesting, we will have to do some testing, but I was able to see the world clock on the testDash you created just fine with
Firefox 18.0.1
Chrome 24.0.13
IE 9
Had another report of this which made me look a little closer, you will want to make sure you have flash player enabled in your browser.
cskang
Post by cskang »
Thanks Scott.
Most likely, it was due to my company's firewall blocking the Flash Player active component reaching out to check with Adobe Flash server before it starts to run.
When I bypass the corporate IT network and directly connect to internet using my cell phone, it worked fine.
Thanks for checking.
cskang
Post by cskang »
It could have been a nice dashlet if it simply works even behind the corporate fire wall.
