Can't Delete BPI HostGroup
mauricio.moya
Post by mauricio.moya »
I was deleting some BPI HostGroup and y have one that i can delete because of a:
"ERROR: Backup successfully created.
Groups Deleted: 0
Unable to match string in config file."
How can i fix and find the string that can't match and delete this hostgroup on BPI ???
thanks!
mguthrie
Re: Can't Delete BPI HostGroup
Post by mguthrie »
You can remove the hostgroup manually be manually editing the BPI config. If you have the latest version of XI (1.6) there is a link to manually edit the BPI config file. You'll just need to find that hostgroup and remove it from the file. Otherwise you can access the URL directly with the following location:
[url]http://<yourserver>/nagiosxi/includes/components/nagiosbpi/index.php?cmd=fixconfig[/url]
mauricio.moya
Ok,
It work's.
Thanks a lot!
