nagios alert
skavalackal
nagios alert
Post by skavalackal »
I got an alert from a website which is hosted in IIS. I don't see any problem with the web site or could not find any 400 error in the server logs. Any idea what is it?
"HTTP WARNING: HTTP/1.1 400 Bad Request
Date/Time: 10/04/2010 14:18:40"
mmestnik
Re: nagios alert
Post by mmestnik »
I'd wager that the server you are actuality getting this response from and the server(or virtual host) you are looking at the logs of are not the same.
skavalackal
Re: nagios alert
I am sure that I checked the correct log. Also the website I am monitoring has no problem,It is up and running.
skavalackal
Re: nagios alert
Any workaround to disable only this alert?. This warning alert is generating from all the websites I monitor which is up and running without any problem.
