Hi Team,
i have to add bandwidth and port status parameters for 1500 routers for that I need a script as per below requirement. Pls do the needful.
It should take multiple hostname, IP and description at single time from a txt or excel file.
It should take only FastEthernet8 and GigabitEthernet0 port with their description for monitoring and bandwidth utilization.
SNMP version (all available version>
SNMP string <some string>
Threshold value for bandwidth in and out <some value>
it should create only above ports entry in mrtg.cfg, also make rrd file for same only.
router parameter adding script
Re: router parameter adding script
If this is something possible to add into the cfgmaker script for mrtg, it would be considered custom development and for that you would need to contact [email protected] to request a quote. We would still need to determine if this is something possible to add.
wiproltdwiv
Ok Thanks,
But please confirm possibility for technical team, post that we can contact to sales team.
I'm not sure I understand your request, you can either email us at [email protected] to open a ticket and talk over your requirements, or you can email [email protected] and they will let us know what is going on.
