Nagiosxi disappear services
Re: Nagiosxi disappear services
File services CONCENI-01.cfg
# Service configuration file
# Created by: Nagios QL Version 3.0.3
# Date: 2010-10-08 11:10:05
# Version: Nagios 3.x config file
# Nagios QL will overwite all manual settings during the next update
host_name CONCENI-01
service_description ALIMENTAZIONI STATUS
servicegroups ENI AREA CLERICI
check_command check_power_fsc!sianagios
is_volatile 0
max_check_attempts 3
check_interval 10
retry_interval 1
check_period 24x7
notification_interval 480
notification_period 24x7
notification_options w,u,c,r
contact_groups admins,enicontact,eni_teps
register 1
service_description CPU
check_command check_cpu!sianagios!80!90
is_volatile 0
check_interval 10
retry_interval 1
check_period 24x7
notification_interval 800
is_volatile 0
check_interval 10
retry_interval 1
check_period 24x7
register 1
is_volatile 0
check_interval 10
retry_interval 1
check_period 24x7
Now
I decided to remove the services of a server CONCENI-01 and then reload the configuration file of the server CONCENI-01with tools import
are now visible again the services do not know what changes from the first
I enclose the current screen
after five minute without doing anything and again disappeared services of the server con-01
Now I would not know what evidence do
Just to summarize, it looks like just the servicegroup associations are being lost - the services are still there I think. I still don't know why, but perhaps that will help someone else figure it out if I don't think of something.
Take a look at config_id, I'm not sure what it should be, however the red error is clear. This can not be active because it belongs to another config.
The views of both the servicegroups hostgroups that you lose the services while remaining hosts
Diego
Diego
I didn't quite copy your last.
Are you renaming hosts? That's going to cause all sorts of headache and pain. Could you explain a little more?
I finished the configuration and everything works and is visible
After five minutes,
the services ...... example ..... check cpu ...... some host .... are no longer associated with the hostgroups and servicegroups
if you look at the pictures I posted you can see with your eyes Though the services are no longer visible if I go into the administration part I can see and edit
what I find very strange is that everything works for a short time and disappear without making changes
you say ..... watch the config_id where is it? in databese? in which table? Thanks
Since this problem is the second time ....that happens..
I thought ......... keep a copy of the basic configuration locahost only then to start from but does not include the services
only host hostgroups template contacts contactgroups
then if it's ok
servicegroups and services ...... hand one at a time
if you have other ideas ...............
I am discouraged .......if think to put it all over again without having the safety features then I worry
bye
Diego
After five minutes,
then if it's ok
bye
Diego
Ok
after placing the configuration still the same problem the services are no longer associated with the hostgroups and servicegroups
sorry but I can not solve the problem
I tried this I went on servicegroups where there are no associated services.
I put some of those services that are not visible.
first I expected it to be error because it was already associated.
Second ..... the services are now associated with servicegroups but not yet visible in the view of servicegroups.
In any case, the software does not behave properly
