Check_WinFile Nagios NRPE help please
csward
Post by csward »
I'm new to Nagios and working my way through it. I need to have a file count on one of my server folders and am trying to get the Check_WinFile plugin working. Here is my config so far:
Commands.cfg:
#check_winfile
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ $ARG1$ $ARG2$
Windows.cfg:
host_name CSXENCLUFS
service_description File Count
check_command check_nrpe!check_winfile
notification_interval 0
Windows NSClient.ini file:
; check_winfile - Alias for alias_volumes. To configure this item add a section called: /settings/external scripts/alias/alias_volumes
check_winfile = check_winfile.exe --target C:\Traces --warn 10 --critical 25
The plugin is installed in the Scripts folder and the Check_WinFile.exe is located C:\Program Files\NSClient++
I continue to get this error:
Return code of 127 is out of bounds - plugin may be missing)
I have defined the plugin, so I'm not sure why it isn't working here. Any help would be appreciated. Thanks
Re: Check_WinFile Nagios NRPE help please
Post by slansing »
The definitions are case sensitive, so if the plugin is indeed named:
Check_WinFile.exe
It must be defined as such, like so:
check_winfile = Check_WinFile.exe --target C:\Traces --warn 10 --critical 25
Also, if you plan to supply custom warning and critical variables to the plugin you will need to set it up to receive arguments, for example the alias I have shown below calls the runcmd.bat script and passes it $ARG1$ that is set from nagios with the -a flag on the check command. Unless you would like to change the warning and critical values by hand in the NSClient/NSC.ini file you would probably want to set them to receive $ARG2$ and $ARG3$ or something along those lines instead of the hard coded values:
Example definition in a NSC.ini file:
servicerestart= scripts\runcmd.bat $ARG1$
csward
Post by csward »
ok, fixed the case sensitive issues. Took out the argument statements and updated my config to something a bit easier as I just want to get it working before adding the arguments. Here is my updated config:
INI file:
; Check File Count
Define Service:
Define Command:#check_winfile
So shouldn't this work? the service points to check_nrpe > the command points to the server > the server ini points to the file and should run, yes?
jsmurphy
Post by jsmurphy »
I think your problem is likely that you need to put the full path to Check_WinFile.exe i.e. C:\program files\nsclient++\scripts\Check_WinFile.exe or whatever the path happens to be.
check_winfile = "C:\program files\nsclient++\scripts\Check_WinFile.exe" --target C:\Traces --warn 10 --critical 25
Nine times out of ten return code 127 means it can't find the path to a plugin.
Ninja edit:
I just realised your nrpe command definition is not accepting any arguments either which is more likely to be your problem...
Should be:
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
csward
Post by csward »
update ***I just realised your nrpe command definition is not accepting any arguments either which is more likely to be your problem...***
-This must be it. I'll take a look at it now.
Ok, so now everything shows good (although its not). Looks like nagios is correctly seeing the check_nrpe plugin (I needed to adjust the plugin location), but now nagios isn't giving me any warning or critical alerts as I have more than the amount of files then the .ini file states
Still continues to give me this:
File Count OK 03-19-2013 16:49:22 0d 0h 43m 49s 1/3 I (0,4,1,73 2012-12-17) seem to be doing fine...
It doesn't seem like it is calling the check_winfile.exe
I also tried specifing the full path in my .ini file:
check_winfile = C:\Program Files\NSClient++\scripts\check_winfile.exe --target C:\Traces --warn 5 --critical 25
Here are the logs I saw:
2013-03-19 16:31:33: l:d:\source\nscp\trunk\modules\checkexternalscripts\commands.hpp:100: Failed to parse arguments for command 'check_winfile', using old split string method: unknown escape sequence: check_winfile.exe --target C:\Traces --warn 5 --critical 25
2013-03-19 16:56:37: l:d:\source\nscp\trunk\modules\checkexternalscripts\commands.hpp:100: Failed to parse arguments for command 'check_winfile', using old split string method: unknown escape sequence: C:\Program Files\NSClient++\scripts\check_winfile.exe --target C:\Traces --warn 5 --critical 25
Any ideas?
csward
Post by csward »
Well, now i'm getting this error. I have adjusted the definitions to be:
#check_winfile
command_line /usr/local/src/nagios-plugins-1.4.16/plugins/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
INI File
; Check File Count
check_winfile = C:\Program Files\NSClient++\scripts\check_winfile.exe --target C:\Traces --warn 5 --critical 8
This is the output I'm getting now:
(No output returned from plugin)
Any reason why this wouldn't be sending the data back?
jsmurphy
Post by jsmurphy »
Which version of NSClient++ is this? If it's v0.3.x then make sure that the command is under the [NRPE Handlers] heading or NSclient will think you're a crazy person.
I'm still not 100% clear with 0.4.x how all this works as we are only just starting to put it into production ourselves, the problem is the documentation on the nsclient++ site hasn't quite caught up yet. With my current understanding of 0.4 it would go under the external scripts/scripts heading... so it would look like this:
check_winfile="C:\Program Files\NSClient++\Scripts\Check_WinFile.exe" --target C:\\Traces --warn 5 --critical 25
I believe a valid alternative format for the command is:
check_winfile=scripts\\Check_WinFile.exe --target C:\\Traces --warn 5 --critical 25
The error message you posted says to me it's trying to escape something so double backslashes should solve that.
csward
Post by csward »
Thanks for the help on this. I'm still a little confused on:
I am using nsclient 0.4x
Are you saying there should be a specific area in the INI file that this goes under? Where are the NRPE handlers?
abrist
Red Shirt
Post by abrist »
In 0.4.x, the NRPE handlers section was absorbed into the "External Scripts" section. Do you have the section "[/settings/external scripts/scripts]" in your ini?
csward
Post by csward »
The closest I have (I'm guessing this is it) is this:
; A list of aliases available. An alias is an internal command that has been "wrapped" (to add arguments). Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
It is under that section. I have attached my INI file to this post.
nsclient.ini
INI File
(7.34 KiB) Downloaded 657 times
