In my Nagios XI 2012R1.6, I have a service that I configured to have flapping disabled.
I think I have successfully disabled flapping because if I go to "See this service in Nagios Core", it reports "Flap Detection: Disabled" and on the Advanced page of the Nagios XI web GUI, the "Flap Detection" indicator is gray with a green check mark next to that.
However, also on the advanced page, it says:
Service Notes:
Service is flapping between states
I may have disabled flap detection while the service was flapping. Is this part of the problem? If so, how do I clear that Note?
Thanks for any help provided.
Service Notes says service is flapping but flapping disabled
Re: Service Notes says service is flapping but flapping disa
This will likely change one the service comes out of flapping.
The only way to force it would be to remove all the current retention data out of Nagios and set all the checks back to pending
to do this you would run
then move the retention.dat file
This will set all the checks to a pending state until all of the items have been checked
service nagios stopCode: Select all
mv /usr/local/nagios/var/retention.dat /usr/local/nagios/var/retention.dat~
service nagios startRe: Service Notes says service is flapping but flapping disa
Thanks for the feedback.
I ended up deleting and re-adding the service for other reasons which also did the trick.
Miles
Miles
Excellent, thanks for letting us know.
