Can nagios be used to monitor embedded devices?
speerless
Post by speerless »
Hello!
I have a question here: Can nagios be used to monitor embedded devices such as the arm.if it could ,should i must migrate the NRPE? if you know the answers,please tell,i have spent lots of time on it ,thank you!!
Re: Can nagios be used to monitor embedded devices?
Post by slansing »
Can you go into more detail? It is a bit difficult to understand this question.
speerless
Post by speerless »
slansing wrote:Can you go into more detail? It is a bit difficult to understand this question.
I am sorry for my express.i am not good at this.
I want to use nagios to monitor a platform of arm,its type is dm355,but i cann't get the nrpe installed ,so during the past days ,i keep on working the cross compiling of the nrpe ,but i didn't workd out .so i want to ask:can nagios be used to monitor my device ,if it could ,whether it has some easy method or plugin.
if you still don't understand my express ,please tell .I truely need your help ,thank you!!
This is going to be somewhat hit or miss. There is a ARM build for Arch Linux here
https://aur.archlinux.org/packages/nagios-nrpe/
speerless
Post by speerless »
scottwilkerson wrote:This is going to be somewhat hit or miss. There is a ARM build for Arch Linux here
I am sorry,i have checked the url, but i still don't understand, does it say that the nrpe itself can be used for the arm directly ,because i found that the nrpe he gived just is the normal type.
I truely don't know how to do it ,please help me ,thank you!
On the right side is a link to the Arch ARM build under "Package Actions"
speerless
Post by speerless »
scottwilkerson wrote:On the right side is a link to the Arch ARM build under "Package Actions"
i see it,but if my arm device doesn't install arch, i can't use it ,right?does it mean that i must change the kernel of my arm?does it also have another easy way?
thanks for your help!
What OS does your ARM device run?
speerless
Post by speerless »
scottwilkerson wrote:What OS does your ARM device run?
My arm device is TI Davinci dm355,the kernel is 'linux 2.6.32',thank you for your help!
I would recommend compiling NRPE from source. You will need openssl and openssl devel packages. Give it a try, and let us know of any issues you ran into. We will try to help you out. Here's the official NRPE documentation:
http://nagios.sourceforge.net/docs/nrpe/NRPE.pdf
