help please?HTTP 403 forbidden
HTTP 403 forbidden
devilsguest
HTTP 403 forbidden
Can you guys suggest me what to do. here today I have installed apache 2.2.24 to my linux machine. Username and password are working fine. But, after I login I see the error message saying
Re: HTTP 403 forbidden
Have you replaced your nagios vhost file (from the previous thread) with the default one?
What does your httpd error logs look like?
tail /var/log/httpd/error_logFormer Nagios employee
devilsguest
here is my basic config file... but i don't see my log files in my /usr/local/apache2/logs.....this file looks empty
ScriptAlias /nagios/cgi-bin "/usr/local/nagios/sbin/"
<Directory "/usr/local/nagios/sbin/">
Options ExecCGI
AllowOverride None
Order allow,deny
Allow from all
AuthName "Nagios Web Access"
AuthType Basic
AuthUserFile /usr/local/nagios/etc/htpasswd.users
Require valid-user
</Directory>
Alias /nagios "/usr/local/nagios/share/"
<Directory "/usr/local/nagios/share/">
Options None
AllowOverride None
Order allow,deny
Allow from all
AuthType Basic
Require valid-user
</Directory>
Is the access_log file empty as well?
tail /var/log/httpd/access_logFormer Nagios employee
Firewall issue, SELinux...?
iptables -L -n
sestatusBe sure to check out our Knowledgebase for helpful articles and solutions!
devilsguest
[b] iptables -L -n[/b]
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
[b] sestatus[/b]
SELinux status: enabled
SELinuxfs mount: /selinux
Current mode: enforcing
Mode from config file: enforcing
Policy version: 18
Policy from config file:targeted
Policy booleans:
allow_syslog_to_console inactive
allow_ypbind inactive
dhcpd_disable_trans inactive
httpd_builtin_scripting active
httpd_disable_trans inactive
httpd_enable_cgi active
httpd_enable_homedirs active
httpd_ssi_exec active
httpd_tty_comm inactive
httpd_unified active
mysqld_disable_trans inactive
named_disable_trans inactive
named_write_master_zonesinactive
nscd_disable_trans inactive
ntpd_disable_trans inactive
pegasus_disable_trans inactive
portmap_disable_trans inactive
postgresql_disable_transinactive
snmpd_disable_trans inactive
squid_disable_trans inactive
syslogd_disable_trans inactive
use_nfs_home_dirs inactive
use_samba_home_dirs inactive
use_syslogng inactive
winbind_disable_trans inactive
ypbind_disable_trans inactive
Try disabling selinux and see if this is going to change anything:
setenforce 0Be sure to check out our Knowledgebase for helpful articles and solutions!
devilsguest
what does it do and what is this all about....can you please explain me little precise....
The command is used to disable selinux.
http://www.cyberciti.biz/faq/howto-turn-off-selinux/
Sometimes selinux can cause this type of issues, that's why I wanted you to disable it, and see if you will be able on view the page.
devilsguest
when i start my apache why do i get this error any idea
httpd: Could not open configuration file /usr/local/conf/httpd.conf: No such file or directory
