Home » Categories » Multiple Categories
NRPE - How to install NRPE
Installing NRPE Using the Install Script
You must run the following commands as root.
cd /tmp
For CentOS & RHEL , Fedora 14+, SLES & OpenSUSE 11+, Ubuntu, Debian:
wget http://assets.nagios.com/downloads/nagiosxi/agents/linux-nrpe-agent.tar.gz
Unpack the installer, and run the install script:
tar xzf linux-nrpe-agent.tar.gz
cd linux-nrpe-agent
./fullinstall
The script takes care of the following setup:
  • Installs prerequisite packages
  • Creates required users and groups
  • Defines services for xinetd
  • Compiles and installs the NRPE agent and Nagios plugins
  • Configures the firewall (except on SLES)
  • Configures the agent
The script will stop to prompt you once to ask for the IP address(es) for your monitoring server(s).
You will need to type either a single address or multiple addresses separated by spaces. This will configure the xinetd superdaemon to allow connections from those addresses to the NRPE agent.
You now have NRPE installed. You may remove any installation files in the tmp directory.
This video covers the steps above.
Installing NRPE From Source
The following KB article describes how to install and configure NRPE from source for use with Nagios Core/XI. The linux-nrpe-agent that ships with Nagios XI is only supported on CentOS, RHEL, OpenSUSE, SLES, Ubuntu, and Debian. Most monitored environments consist of many different distributions, therefore may need to compile NRPE and its associated plugins.
Documentation - How To Install NRPE v3 From Source
Final Thoughts
2.5 (18)
Article Rating (18 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Installing The Linux Agent
Viewed 13959 times since Wed, Jan 27, 2016
NRPE - Upgrading To NRPE v3 From Source
Viewed 12629 times since Mon, Jul 11, 2016
Nagios XI - Installing the XI Mac OS/X Agent
Viewed 5968 times since Wed, Jan 27, 2016
Nagios XI - Monitoring Linux Using NRPE and Linux Server Monitoring Wizard
Viewed 5584 times since Mon, Oct 16, 2017
NRPE - How to install NRPE from source without xinetd on CentOS 6.
Viewed 13608 times since Wed, Apr 15, 2015
Nagios XI - Upgrading The Linux NRPE Agent
Viewed 7268 times since Wed, Aug 30, 2017
NRPE - How To Install NRPE v4 From Source
Viewed 333978 times since Fri, Jun 3, 2016
NRPE - Packet Size Explained
Viewed 26345 times since Thu, Jun 30, 2016
Nagios XI - Installing The Solaris Agent
Viewed 6154 times since Wed, Jan 27, 2016
Nagios XI - Monitoring AIX With Nagios
Viewed 6650 times since Thu, Jan 28, 2016
