Home » Categories » Products » Nagios XI » Troubleshooting » Common Problems
Nagios XI - Core 4 Load Spikes on 1.75 and 7 Hour Intervals
Problem Description
With the release of Nagios XI 2014 the core version on the back-end was updated to Core 4. This introduced a issue in certain environments where an extremely high system level load can occur at intervals most commonly between an hour and seven hours of the Nagios process starting.
Editing Files
In many steps of this article you will be required to edit files. This documentation will use the vi text editor. When using the vi
editor:
  • To make changes press i on the keyboard first to enter insert mode
  • Press Esc to exit insert mode
  • When you have finished, save the changes in vi by typing :wq and press Enter
Resolving The Problem
As a temporary solution to this we recommend that if you have been experiencing this problem, you should modify:
/usr/local/nagiosxi/html/config.inc.php
By changing the following line:
"nom_checkpoint_interval" => 1440, // time (in minutes) between nom checkpoints
To:
"nom_checkpoint_interval" => 90, // time (in minutes) between nom checkpoints
You may want to alter the above noted interval based on when you are experiencing these problems.
Ideally it should be set to occur as close to the high load anomaly as possible as to minimize system downtime and stress while we work towards a more permanent solution.
This will force the creation of a snapshot, so you may want to archive any important config snaphots as these changes will increase the number of daily snapshots (possibly pushing needed snapshots from the pool).
Final Thoughts
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Installing Latest SourceGuardian Loaders
Viewed 6168 times since Mon, Jun 18, 2018
Installation errors on customized corporate builds of CentOS or RHEL
Viewed 9816 times since Tue, Jan 26, 2016
Nagios XI - Notification Problems
Viewed 25871 times since Tue, Jan 27, 2015
Nagios XI - Reset Upgrade Status In Web Interface
Viewed 9540 times since Tue, May 7, 2019
Nagios XI - MRTG Reports SNMP_Session Errors
Viewed 4356 times since Wed, Jul 27, 2016
Nagios XI - Disabling Database UTF8 Connectivity
Viewed 4608 times since Thu, Mar 8, 2018
Nagios XI - ERROR: PostgresQL not running - exiting
Viewed 4395 times since Tue, Jan 26, 2016
Nagios XI - Can’t Log Into The Web Interface
Viewed 55620 times since Tue, Jan 27, 2015
Nagios XI - CentOS 6 Installation Problems XI 2011R1.7 2011R1.8
Viewed 4197 times since Tue, Feb 2, 2016
Nagios XI - SNMP MIB Upload Problems
Viewed 7680 times since Mon, Apr 10, 2017
