Home » Categories » Multiple Categories
Nagios XI - SNMP MIB Upload Problems
Overview
This KB article provides solutions to issues that can arise when uploading SNMP MIB files.
Permissions
Some problems are caused by incorrect permissions on the SNMP MIB files.
If you receive one of these errors:
failed to convert to snmptt mib
MIB could not be installed - directory permissions may be incorrect.
Execute the following commands to reset the permissions and ownership:
chmod -R ug+rw /usr/share/snmp/mibs
chown -R root:nagios /usr/share/snmp/mibs
After executing those commands you should be able to upload the MIB file that previously did not work.
Modules Missing
MIBs can require modules that are defined in other MIBs. If you have uploaded a MIB to Nagios XI and the required modules are missing, you might notice some warnings when executing Net-SNMP commands in a terminal session.
For example, after uploading the MIB CISCO-IMAGE-MIB.my file you receive these warnings when using the snmpwalk command:
MIB search path: /root/.snmp/mibs:/usr/share/snmp/mibs
Cannot find module (CISCO-SMI): At line 24 in /usr/share/snmp/mibs/CISCO-IMAGE-MIB.my
Did not find 'ciscoMgmt' in module #-1 (/usr/share/snmp/mibs/CISCO-IMAGE-MIB.my)
Unlinked OID in CISCO-IMAGE-MIB: ciscoImageMIB ::= { ciscoMgmt 25 }
Undefined identifier: ciscoMgmt near line 27 of /usr/share/snmp/mibs/CISCO-IMAGE-MIB.my
In the error above the CISCO-SMI module appears to be missing. After uploading the MIB CISCO-SMI.my file you will not receive the warnings.
The explanation is that the Net-SNMP commands look at all the MIB files in the /usr/share/snmp/mibs/ folder when executing. The commands will display warnings if the modules are missing. You don't often see these warnings in the Nagios XI interface as this output is hidden, you commonly only see the warnings when in a terminal session.
It's worth mentioning that the filename "CISCO-SMI.my" is not how Net-SNMP knows that the the module is located in this file. This line in the file defines it:
CISCO-SMI DEFINITIONS ::= BEGIN
The fact that the file is named "CISCO-SMI.my" is irrelevant, however Cisco have made it easy by keeping the filename the same as the module definition name.
Final Thoughts
3.5 (2)
Article Rating (2 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
VMWare checks timing out or slow
Viewed 2588 times since Fri, Feb 11, 2022
Nagios XI - Hosts Pending/Gray
Viewed 10177 times since Tue, Jan 6, 2015
SNMP Trap - snmptrapd Service
Viewed 60507 times since Tue, Mar 24, 2015
Nagios XI - MSSQL Query Wizard - Invalid characters in the username
Viewed 4617 times since Thu, Aug 3, 2017
Nagios XI - Problems with $ Signs in the Check Command
Viewed 7142 times since Tue, Jan 26, 2016
Nagios XI - MRTG Reports SNMP_Session Errors
Viewed 4288 times since Wed, Jul 27, 2016
Nagios XI - MSSQL Wizards - Adaptive Server connection failed
Viewed 9803 times since Thu, Aug 3, 2017
PHPMailer - Troubleshooting Using Debug Logging
Viewed 19022 times since Tue, Aug 14, 2018
Nagios XI - Scheduled Reports Not Running
Viewed 4930 times since Thu, Aug 10, 2017
Nagios XI - Core 4 Load Spikes on 1.75 and 7 Hour Intervals
Viewed 3846 times since Mon, Jan 25, 2016
