Home » Categories » Products » Nagios XI » Documentation » Monitoring Configuration
Nagios XI - Understanding And Using Configuration Wizards
Understanding And Using Configuration Wizards In Nagios XI
This document is intended for use by Nagios Administrators that wish to get a thorough understanding of how
Configuration Wizards work in Nagios XI.
Documentation - Understanding And Using Configuration Wizards In Nagios XI
This video introduces you to Configuration Wizards which are very easy to set up configuration settings for certain items you want to monitor inside your network. Watch Aaron do a step-by-step guide on how to set these up.
In this video, we continue to work our way through a Nagios XI configuration wizard to help users understand how they work and give them an example so they can easily monitor their own environment.
In this video, we focus on the last step of the configuration wizard process, specifically concerning host groups, service groups and parent child relationships.
Watch this video to learn about a way to quickly add a new element to your monitoring environment with Configuration Wizard Templates.
Final Thoughts
0 (0)
Article Rating (No Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Nagios XI - Running Auto-Discovery Jobs
Viewed 5342 times since Wed, Jul 19, 2017
Nagios XI - Core Config Manager - How It Works
Viewed 4433 times since Sun, Jul 30, 2017
Nagios XI - Adding Services To Pre-existing Switch or Router
Viewed 8240 times since Wed, Jan 27, 2016
Nagios XI - Monitoring Apache Tomcat With XI
Viewed 4426 times since Wed, Jan 27, 2016
Nagios Core - SNMP Explained - NWC15
Viewed 11202 times since Mon, Feb 8, 2016
Nagios XI - Excluding Hosts And Hostgroups
Viewed 5361 times since Tue, May 2, 2017
Nagios XI - Using The Config Import Prep Tool
Viewed 10477 times since Thu, Jan 28, 2016
Nagios XI - Restarting A Linux Service With NRPE
Viewed 6086 times since Thu, Jan 28, 2016
Nagios XI - How SNMP Traps Work
Viewed 5250 times since Mon, Nov 18, 2019
Nagios XI - Restarting Windows Services With NCPA
Viewed 4477 times since Tue, Mar 20, 2018
