Home » Categories » Multiple Categories
Nagios XI - Using Web SSH Terminal
This KB article shows you how to use the web SSH terminal that comes with Nagios XI. The SSH terminal is available as part of the enterprise edition license.
The SSH terminal is located by navigating to Admin > System Config > SSH Terminal.
The terminal uses a self-signed certificate that needs to be added as an exception before it can be used. Click the Open terminal in a new window link to do this.
This example shows how Mozilla Firefox handles certificate exceptions, other web browsers will have similar methods. Click the Advanced button and then click the Add Exception button.
In the screenshot above you will need to click the Confirm Security Exception button to proceed. Once this has done the screen will refresh and the terminal window will appear, close this window.
Refresh the SSH terminal screen by navigating to Admin > System Config > SSH Terminal.
Here you are presented with an embedded SSH terminal session. You can login to this just like you would using an SSH client.
Note: Be aware that if you navigate away from this screen your session will be disconnected. You should try and use the Open terminal in a new window link where possible to maintain an open SSH session.
Final Thoughts
3 (2)
Article Rating (2 Votes)
Rate this article
  • Icon PDFExport to PDF
Attachments Attachments
Related Articles RSS Feed
Converting PostgreSQL to MySQL for Nagios XI
Viewed 21603 times since Tue, Dec 6, 2016
Nagios XI - Profile Build Failed
Viewed 5042 times since Tue, Aug 2, 2016
Nagios XI - Uploading and Managing MIBS
Viewed 4907 times since Thu, Aug 1, 2019
SSL/TLS - Signing Certificates With A Microsoft Certificate Authority
Viewed 6017 times since Wed, Jun 14, 2017
Nagios XI - Getting Started Tips
Viewed 2376 times since Thu, Dec 6, 2018
Nagios XI - Enabling Ping Action
Viewed 2036 times since Wed, Jul 19, 2017
Nagios XI - Mass Delete Old RRD Files
Viewed 1795 times since Tue, Sep 10, 2019
Nagios XI - MySQL/MariaDB - Max Connections
Viewed 16350 times since Thu, Jun 2, 2016
Nagios XI - Optimizing The PHP Settings File
Viewed 9911 times since Thu, Jul 13, 2017
Nagios XI - Using DUO Two Factor Authentication
Viewed 2225 times since Tue, Jan 8, 2019
