Home »
Categories
» Products » NRPE » Troubleshooting » Common Problems |
NRPE - Connection Refused By Host |
Article Number: 622 | Rating: 1/5 from 1 votes | Last Updated by tlea on Mon, Jul 17, 2017 at 12:49 AM
Problem Description
This KB article addresses the following NRPE error:
Assumed Knowledge
The following KB article contains an explanation of how NRPE works and may need to be referenced to completely understand the problem and solution that is provided here:
NRPE - Agent and Plugin Explained
Troubleshooting The Error
This error usually relates to port/firewall issues or improperly configured "allowed_hosts" directives. Please refer to the following KB articles for the relevant troubleshooting steps:
NRPE - CHECK_NRPE: Error - Could Not Complete SSL Handshake
NRPE - CHECK_NRPE: Socket Timeout After n Seconds
Final Thoughts
Posted by: tlea on Mon, Jul 17, 2017 at 12:49 AM. This article has been viewed 13769 times. Filed Under: Common Problems |
Have a question? Try our Forums! | Give Feedback |
1 (1)
Article Rating (1 Votes)
Rate this article
| Related Articles
NRPE - Connection Refused Or Timed Out
Viewed 8314 times since Mon, Jul 17, 2017
NRPE - UNKNOWN: No Handler For That Command
Viewed 12825 times since Mon, Jul 17, 2017
Viewed 56113 times since Fri, Jul 14, 2017
NRPE - General Troubleshooting Tips
Viewed 14630 times since Mon, Jul 17, 2017
