Have had nothing but issues from the start
I'm wondering if support gave us the wrong .ova. Nothing but issues from the start, like the VM only having 2 GB of RAM and a 60 GB disk. Support - can you delete this post? I made a much better one. Thanks.
Last edited by omarrrthepirate on Tue Aug 31, 2021 4:22 pm, edited 1 time in total.
Omarrr The Pirate!
Arrrrr
Arrrrr
Re: This product is TOO nerdy for me
I only partially agree with the second part of your statement. The learning curve could be steep if you are using the advanced configuration options, e.g. Core Config Manager. In the majority of the cases, you don't need to use the CCM. You could configure your hosts and services using the Nagios XI configuration wizards. The use of the configuration wizards is very easy and self-explanatory. Even a non-technical person can use them.This product can obviously do anything and everything under the sun, but my goodness the learning curve is steep!
Most likely, you have your notification_period configured "locally" (on the host level), which takes precedence over the template. Please read more on the "Local Variables vs. Inherited Variables" in our official Nagios Core documentation:I thought I configured the right template so that I only get notified ONCE when a host goes down or changes state, but then I go to each individual server and they still have the 60 mins re-notification period configured.
https://assets.nagios.com/downloads/nag ... tance.html
You can go to the CCM > Hosts > <your host> > Alert Setting tab then set the Notification interval to 0 (zero), click on Save, and apply configuration. Nagios will notify you only once about the issue.
Host - notification interval
This directive is used to define the number of "time units" to wait before re-notifying a contact that this service is still down or unreachable. Unless you've changed the interval_length directive from the default value of 60, this number will mean minutes. If you set this value to 0, Nagios will not re-notify contacts about problems for this host - only one problem notification will be sent out.
Parameter name: notification_interval
Required: yes
I am not sure why you think it is annoying when the templates are active. Most probably, only one or two are used in your config. You can easily view your host and services configs, and determine which templates are in use. You can achieve this by going to:Also, there are so many templates, and the fact that they are ALL active by default, is very annoying. I don't know how many templates are controlling my config.
CCM > Hosts > <your host> > View config
Example: The template that is in use is defined by the "use" directive:
# Hosts configuration file
# Created by: Nagios CCM 3.1.3
# Date: 2021-08-25 09:49:48
# Version: Nagios Core 4.x
# Nagios CCM will overwrite all manual settings during the next update if you
# would like to edit files manually, place them in the 'static' directory or
# import your configs into the CCM by placing them in the 'import' directory.
define host {
host_name HP-M1530
use xiwizard_printer_host
alias HP LaserJet M1530 MFP Series PCL 6
address 192.168.x.x
max_check_attempts 5
check_interval 5
retry_interval 1
contacts nagiosadmin
notification_interval 60
first_notification_delay 0
notifications_enabled 1
_xiwizard printer
register 1
# END OF FILE
Adding a host to a hostgroup, doesn't remove it from another hostgroup. A host could be a member of two different hostgroups. You can remove it from the group that you don't want it to be a member of.Additionally, there are a few servers that got put in the Windows-Server group when they should be in the Linux Server group. When I go to re-configure the host, the Windows-Servers group is not checked, so I check the Linux Servers group and it remains in both groups -- even when I add it to the Windows group, save, and un-check the Windows Servers group. It still remains in both groups.
There are two ways of doing that. Some users like one of the ways over the other. It is a matter of preference really.
1. METHOD - Add a host to a hostgroup
CCM > Host Groups > <your hostgroup> > Manage Hosts > Add Selected (or Remove) > Close > Save > Apply Configuration
2. METHOD - add a hostgrtoup to a host
CCM > Hosts > <your host> > Manage Host Groups > Add Selected (or Remove) > Close > Save > Apply Configuration
You would be able to see if your host has been already added as a member of a hostgroup in the Manage Host Groups window.
No matter what method you use to manage you hostgroups - the effect is the same as far as monitoring goes. Again, it is just a matter of preference.
The support forum is a great place to get some help and feedback, not only from the Nagios support team, but also from other Nagios XI users. You can also learn more about Nagios XI by watching training videos (as you mentioned) and reading our official Nagios XI documentation here:I guess I'm back to watching more videos because our support doesn't include remote sessions or phone calls, so it's not really worth much.
https://library.nagios.com/library/prod ... mentation/
For a specific problems, you can post on the forum or search our knowledge base here:
https://support.nagios.com/kb/
Hope this helps.
