Nagios Core 4.4.9 and change status at the end period
Post Reply
emi65
Post by emi65 »
Hi
I'm looking for a solution for this functionality
I set up a check with a check period from 8.00am to 20.00
I like to get a function to set the check result to OK at the end of check period
Does it possible to do that ?
Thanks and regards
Emilio
danderson
Re: Nagios Core 4.4.9 and change status at the end period
Post by danderson »
Thanks for reaching out @emi65,
I don't think there is a way to alter the result of a check. However, I'm assuming this is to prevent notifications from occuring when the host is not active. You can do this by setting the notification_period setting in the object definition. You can specifications here.
Post Reply
