Nagios XI - SNMP V3 with DES Protocol Not Available
Post Reply
TLDLinux82
Post by TLDLinux82 »
We are trying to add an SNMP Check to Nagios XI to monitor Meraki Controllers, we need to use DES privacy protocol.
The only options we have are either "None" or "AES"
See screenshot attached.
We can only use DES.
Does anyone have any ideas on how to resolve this and enable DES in the interface? Or is this not something that can be done?
jsimon
Re: Nagios XI - SNMP V3 with DES Protocol Not Available
Post by jsimon »
Unfortunately no, I don't believe there is a way to enable DES encryption in XI.
Post Reply
