We are currently undergoing a trial of the product
1) I presume we can create custom index patterns of our own and they will be maintained by the internal lifecycle mgt, as long as they are time-series based, just like the default logstash index pattern e.g.
[myindexname]-YYYY.MM.DD
2) Does the Nagioslogserver implementation of the dashboard allow building visualizations on sub-groups based on specific fields? A typical use case we have is to capture all API logs showing the service called, the client who made the call and the duration. e.g assume we ingest the following fields into our index that captures all API calls. The
[duration]
[service] [client] [call_start] [call_end] [duration]
Regards,
Dayo
