Nagios 5.6.3 still shows update in progress
Hey, guess what? This (https://support.nagios.com/forum/viewtopic.php?t=46218) happened to me doing a 5.5.11 -> 5.6.3 upgrade on our demo server. Exact same thing except version numbers have changed. Restarted everything, rebooted box, all that jazz. Still shows " Update in progress. Please wait. Update may take a few minutes. "
Re: Nagios 5.6.3 still shows update in progress
To reset that messages, run this command to clear it out of the GUI.
If the nagiosxi database is on the MYSQL server, run this
echo "update xi_commands set status_code = '2' where command = '1120';" | mysql -u root -pnagiosxi nagiosxi
If it is on the Postgres database, run this
echo "update xi_commands set status_code = '2' where command = '1120';" | psql nagiosxi nagiosxi
post...gres? What is this "after gres" thing that you refer to?
So that gave me a "The update did not complete successfully. Please try updating manually," and a "go back" button. After pressing "go back," and checking for updates again just to make sure, all is well.
Thanks.
Thanks.
post..gres is better than no..gres....
Glad it worked.
Glad it worked.
