Integration Nagios3 withServiceNow
Alex_galych
Post by Alex_galych »
Hello.
I'm trying setup automatically sending notifications to ServiceNow.
I have used this guide: https://support.nagios.com/kb/article.php?id=552
All steps, before "Create Notification Commands" successfully, have been made successfully
But when I run command:
./sn_ticketer.pl --page="incident.do" --host="$HOSTNAME$" --state="$HOSTSTATE$" --category="Nagios" --short_description="$HOSTNAME$ is $SERVICESTATE$" --description="Host: $HOSTNAME$\nState: $HOSTSTATE$\nTime: $LONGDATETIME$\nDescription: $HOSTOUTPUT$\n\n"
I get following error:
Cleaning up archived DB entries older than TTL
Config loaded.
Message hash for this alert is: 942d6adecde04c7f2656aa33c6ffb25c
Can't call method "rows" on an undefined value at ./sn_ticketer.pl line 54.
Somebody knows how can I resolve this error?
bolson
Re: Integration Nagios3 withServiceNow
Post by bolson »
Hello Alex,
The error message suggests that the query:
"SELECT id FROM tbl_sn_ticket_tracker WHERE hostname = ? AND servicename = ? AND date_modified > DATE_SUB(NOW(), INTERVAL ? MINUTE)"
Is not returning any rows of data. Can you re-check your configuration?
Alex_galych
Hello!
Thank you for replay.
"Is not returning any rows of data. Can you re-check your configuration? " -- how can I check it?
The only result is "Can't call method "rows""
But for testing I have commented the following lines:
if ($dbResults->rows >= $hrMainConf->{'storm_watch'}->{'sw_service_tickets'}) {
      snt_log("Service: $ARGV{'service'} has tried to log too many tickets");
      $dbResults->finish();
    $bWriteHoldDown = 1;
And now script is working:
root@nagios3:/etc/nagios-plugins/config# ./sn_ticketer.pl --page="incident.do" --host="$HOSTNAME$" --state="$HOSTSTATE$" --category="Nagios" --short_description="$HOSTNAME$ is $SERVICESTATE$" --description="Host: $HOSTNAME$\nState: $HOSTSTATE$\nTime: $LONGDATETIME$\nDescription: $HOSTOUTPUT$\n\n"
Config loaded.
Message hash for this alert is: a1c6b279e8b544cf22de56ef85f05835
Ticket track enabled using database.
Existing ticket found, updating.
Ticket related to SN ID: c279cfcadb984300da15d5f0cf9619b2 has been updated.
Completed succesfully.
I didn't learn Perl language. Do this action can resolve the issue?
Then I added lines to the file /etc/nagios3/commands.cfg:
# 'notify-host-by-snt_service_now' command definition
        command_name    notify-host-by-snt
        command_line    /etc/nagios-plugins/config/sn_ticketer.pl --page="incident.do" --host="$HOSTNAME$" --state="$HOSTSTATE$" --category="Nagios" --short_description="$HOSTNAME$ is $SERVICESTATE$" --description="Host: $HOSTNAME$\nSta$
# 'notify-service-by-snt_service_now' command definition
        command_name    notify-service-by-snt
        command_line    /etc/nagios-plugins/config/sn_ticketer.pl --page="incident.do" --host="$HOSTNAME$" --state="$HOSTSTATE$" --category="Nagios" --short_description="$SERVICEDESC$ on $HOSTNAME$ is   $SERVICESTATE$" --description="Ho$
When test service is down Nagios3 sends email notification but doesn't send event notification to the ServiceNow Instance.
bolson
Post by bolson »
Run the following command with the password you created when you installed the service now integration package:
mysql -u servicenow -p your_password -h localhost
Then run the following commands from the mysql prompt:
mysql>use nagsnt
mysql>select * from tbl_sn_ticket_tracker;
And post your results.
Alex_galych
mysql> use nagsnt
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql> select * from tbl_sn_ticket_tracker;
| id | hostname | servicename | date_created | date_modified | sys _id | archived | message_hash |
| 1 | GFL-1495$ | NULL | 2017-08-02 11:17:38 | 2017-08-03 11:52:25 | c27 9cfcadb984300da15d5f0cf9619b2 | false | 2977d27d346ce7e9332c7a2237d36d08 |
1 row in set (0,00 sec)
bolson
Post by bolson »
When you run the command:
Are you populating the argument variables $HOSTNAME$, $HOSTSTATE$, $SERVICESTATE$, $LONGDATETIME$, and $HOSTOUTPUT$ with actual data?
Can you copy and paste the command exactly as you're running it?
Alex_galych
Hello!
Nagios:/etc/nagios-plugins/config# ./sn_ticketer.pl --page="incident.do" --host="$HOSTNAME$" --state="$HOSTSTATE$" --category="Nagios" --short_description="$HOSTNAME$ is $SERVICESTATE$" --description="Host: $HOSTNAME$\nState: $HOSTSTATE$\nTime: $LONGDATETIME$\nDescription: $HOSTOUTPUT$\n\n"
Config loaded.
Message hash for this alert is: 35c08880b511e773104996136e161478
In attachment there is my field_map.ini file which contains parameters using by sn_ticketer.pl script
field_map.ini
field_map.ini
(3.42 KiB) Downloaded 271 times
Alex_galych
Hello!
I have found a new incident in the ServiceNow instance from Nagios. I expected to see them on All Events of Event management.
https://gyazo.com/c37c67f4cb95d5ea740cdc5a18914f90
Also I have error if run manualy:
SOAP-ENV:Server com.glide.processors.soap.SOAPProcessingException: Web service update called for a missing record: c279cfcadb984300da15d5f0cf9619b2 com.glide.processors.soap.SOAPProcessingException: Web service update called for a missing record: c279cfcadb984300da15d5f0cf9619b2
Most of fields don't populate. How can I fix it?
Alex_galych
So, I rebuld config_file using this command:
sn_ticketer.pl --page='[b]em_event.do[/b]' --buildmap
Then, I run command:
./sn_ticketer.pl --page="em_event.do" --host="$HOSTNAME$" --state="$HOSTSTATE$" --category="Nagios" --short_description="$HOSTNAME$ is $SERVICESTATE$" --description="Host: $HOSTNAME$\nState: $HOSTSTATE$\nTime: $LONGDATETIME$\nDescription: $HOSTOUTPUT$\n\n"
Now all new events appear in the "All events".
But still the most fields are empty. What is a reason of this problem?
Post by mcapra »
The fields might be empty because those macros (like $HOSTNAME$ and $HOSTSTATE$) are evaluated within Nagios Core at run-time. They are not present as proper Linux environment variables unless you have enable_environment_macros enabled. Even then, since there is no context under which a $HOSTNAME$ exists when you're running it as a one-off from the CLI, you might still have empty fields.
Try plugging in simple plain-text values to see if the fields are properly populated.
