Problem install MIB-Directory permissions may be incorrect
fogier
Re: Problem install MIB-Directory permissions may be incorre
Post by fogier »
First ran these command:
chown -R root.nagios /usr/share/snmp/mibs
Now I'm getting an error when clicking on Admin - Manage MIBs:
snmptt.ini is not writable by Nagios.
Run the following from the command line:
chown root.nagios /etc/snmp/snmptt.ini /etc/snmp
chmod g+w /etc/snmp/snmptt.ini /etc/snmp
I've ran these commands aswell. That's solves the error.
The error about the permissions not being right is solves aswell.
Result:
[root@SERVER libexec]# ll -d /usr/share/snmp/
drwxr-xr-x. 5 root root 4096 May  8 14:41 /usr/share/snmp/
[root@SERVER libexec]# ll -d /usr/share/snmp/mibs
drwxrwxr-x. 2 root nagios 4096 May 24 15:04 /usr/share/snmp/mibs
[root@SERVER libexec]# ll /usr/share/snmp/mibs
total 2088
-rw-rw-r-- 1 root nagios  17455 Apr 23 13:53 AGENTX-MIB.txt
-rw-rw-r-- 1 root nagios  50948 Apr 23 13:53 BRIDGE-MIB.txt
-rw-r--r-- 1 root nagios 295284 May 24 15:04 chkpnt.mib
-rw-rw-r-- 1 root nagios  68104 Apr 23 13:53 DISMAN-EVENT-MIB.txt
-rw-rw-r-- 1 root nagios  24613 Apr 23 13:53 DISMAN-SCHEDULE-MIB.txt
-rw-rw-r-- 1 root nagios  64311 Apr 23 13:53 DISMAN-SCRIPT-MIB.txt
-rw-rw-r-- 1 root nagios  84492 Apr 23 13:53 EtherLike-MIB.txt
-rw-rw-r-- 1 root nagios   4660 Apr 23 13:53 HCNUM-TC.txt
-rw-rw-r-- 1 root nagios  52544 Apr 23 13:53 HOST-RESOURCES-MIB.txt
-rw-rw-r-- 1 root nagios  10583 Apr 23 13:53 HOST-RESOURCES-TYPES.txt
-rw-rw-r-- 1 root nagios   4819 Apr 23 13:53 IANA-ADDRESS-FAMILY-NUMBERS-MIB.txt
-rw-rw-r-- 1 root nagios  29665 Apr 23 13:53 IANAifType-MIB.txt
-rw-rw-r-- 1 root nagios   4299 Apr 23 13:53 IANA-LANGUAGE-MIB.txt
-rw-rw-r-- 1 root nagios   3513 Apr 23 13:53 IANA-RTPROTO-MIB.txt
-rw-rw-r-- 1 root nagios   5066 Apr 23 13:53 IF-INVERTED-STACK-MIB.txt
-rw-rw-r-- 1 root nagios  71691 Apr 23 13:53 IF-MIB.txt
-rw-rw-r-- 1 root nagios  16782 Apr 23 13:53 INET-ADDRESS-MIB.txt
-rw-rw-r-- 1 root nagios  46286 Apr 23 13:53 IP-FORWARD-MIB.txt
-rw-rw-r-- 1 root nagios 185667 Apr 23 13:53 IP-MIB.txt
-rw-rw-r-- 1 root nagios  15936 Apr 23 13:53 IPV6-ICMP-MIB.txt
-rw-rw-r-- 1 root nagios  48703 Apr 23 13:53 IPV6-MIB.txt
-rw-rw-r-- 1 root nagios   7257 Apr 23 13:53 IPV6-TCP-MIB.txt
-rw-rw-r-- 1 root nagios   2367 Apr 23 13:53 IPV6-TC.txt
-rw-rw-r-- 1 root nagios   4400 Apr 23 13:53 IPV6-UDP-MIB.txt
-rw-rw-r-- 1 root nagios   5931 Apr 23 13:53 LM-SENSORS-MIB.txt
-rw-rw-r-- 1 root nagios  42375 Apr 23 13:53 MTA-MIB.txt
-rw-rw---- 1 root nagios  19760 Jun 11  2012 NAGIOS-NOTIFY-MIB.txt
-rw-rw---- 1 root nagios   2093 Jun 11  2012 NAGIOS-ROOT-MIB.txt
-rw-rw-r-- 1 root nagios  15732 Apr 23 13:53 NET-SNMP-AGENT-MIB.txt
-rw-rw-r-- 1 root nagios   9160 Apr 23 13:53 NET-SNMP-EXAMPLES-MIB.txt
-rw-rw-r-- 1 root nagios   9198 Apr 23 13:53 NET-SNMP-EXTEND-MIB.txt
-rw-rw-r-- 1 root nagios   2036 Apr 23 13:53 NET-SNMP-MIB.txt
-rw-rw-r-- 1 root nagios   3351 Apr 23 13:53 NET-SNMP-PASS-MIB.txt
-rw-rw-r-- 1 root nagios   4686 Apr 23 13:53 NET-SNMP-TC.txt
-rw-rw-r-- 1 root nagios   5039 Apr 23 13:53 NET-SNMP-VACM-MIB.txt
-rw-rw-r-- 1 root nagios  21006 Apr 23 13:53 NETWORK-SERVICES-MIB.txt
-rw-rw-r-- 1 root nagios  24694 Apr 23 13:53 NOTIFICATION-LOG-MIB.txt
-rw-rw-r-- 1 root nagios   3067 Apr 23 13:53 RFC1155-SMI.txt
-rw-rw-r-- 1 root nagios  79667 Apr 23 13:53 RFC1213-MIB.txt
-rw-rw-r-- 1 root nagios   1174 Apr 23 13:53 RFC-1215.txt
-rw-rw-r-- 1 root nagios 147822 Apr 23 13:53 RMON-MIB.txt
-rw-rw-r-- 1 root nagios  45323 Apr 23 13:53 SCTP-MIB.txt
-rw-rw-r-- 1 root nagios   4595 Apr 23 13:53 SMUX-MIB.txt
-rw-rw-r-- 1 root nagios  15490 Apr 23 13:53 SNMP-COMMUNITY-MIB.txt
-rw-rw-r-- 1 root nagios  22342 Apr 23 13:53 SNMP-FRAMEWORK-MIB.txt
-rw-rw-r-- 1 root nagios   5496 Apr 23 13:53 SNMP-MPD-MIB.txt
-rw-rw-r-- 1 root nagios  20014 Apr 23 13:53 SNMP-NOTIFICATION-MIB.txt
-rw-rw-r-- 1 root nagios   9106 Apr 23 13:53 SNMP-PROXY-MIB.txt
-rw-rw-r-- 1 root nagios  22769 Apr 23 13:53 SNMP-TARGET-MIB.txt
-rw-rw-r-- 1 root nagios  39201 Apr 23 13:53 SNMP-USER-BASED-SM-MIB.txt
-rw-rw-r-- 1 root nagios   2205 Apr 23 13:53 SNMP-USM-AES-MIB.txt
-rw-rw-r-- 1 root nagios  21101 Apr 23 13:53 SNMP-USM-DH-OBJECTS-MIB.txt
-rw-rw-r-- 1 root nagios   8263 Apr 23 13:53 SNMPv2-CONF.txt
-rw-rw-r-- 1 root nagios  29305 Apr 23 13:53 SNMPv2-MIB.txt
-rw-rw-r-- 1 root nagios   8924 Apr 23 13:53 SNMPv2-SMI.txt
-rw-rw-r-- 1 root nagios  38034 Apr 23 13:53 SNMPv2-TC.txt
-rw-rw-r-- 1 root nagios   5775 Apr 23 13:53 SNMPv2-TM.txt
-rw-rw-r-- 1 root nagios  34162 Apr 23 13:53 SNMP-VIEW-BASED-ACM-MIB.txt
-rw-rw-r-- 1 root nagios  28564 Apr 23 13:53 TCP-MIB.txt
-rw-rw-r-- 1 root nagios  16418 Apr 23 13:53 TRANSPORT-ADDRESS-MIB.txt
-rw-rw-r-- 1 root nagios   2163 Apr 23 13:53 UCD-DEMO-MIB.txt
-rw-rw-r-- 1 root nagios   4402 Apr 23 13:53 UCD-DISKIO-MIB.txt
-rw-rw-r-- 1 root nagios   3010 Apr 23 13:53 UCD-DLMOD-MIB.txt
-rw-rw-r-- 1 root nagios   8118 Apr 23 13:53 UCD-IPFWACC-MIB.txt
-rw-rw-r-- 1 root nagios  46150 Apr 23 13:53 UCD-SNMP-MIB.txt
-rw-rw-r-- 1 root nagios  20882 Apr 23 13:53 UDP-MIB.txt
sreinhardt
-fno-stack-protector
Post by sreinhardt »
Permissions look great, and fantastic to hear that it is working now! Let us know if there is anything else we can do!
