Problem install MIB-Directory permissions may be incorrect
fogier
Post by fogier »
I'm trying to upload a MIB via the webinterface but it gives me a error "MIB could not be installed - directory permissions may be incorrect.".
I've searched this forum and there are a lot of people having this issues. Pretty strange since I downloaded your virtual machine.
I'm using Nagios XI Enterprise 2012 v1.6 (x64, vsphere virtual machine download from your site), CentOS 6.3.
[root@SV16863 snmp]# ls -ld /usr/share/snmp/mibs/
drwxrwxr-x. 2 root nagios 4096 May  8 14:41 /usr/share/snmp/mibs/
It was root.root but I used the commands here to change that-> http://support.nagios.com/forum/viewtop ... ect#p24620
[root@SV16863 snmp]# ll /usr/share/snmp/mibs/
total 1796
-rw-r--r-- 1 root root    17455 Apr 23 13:53 AGENTX-MIB.txt
-rw-r--r-- 1 root root    50948 Apr 23 13:53 BRIDGE-MIB.txt
-rw-r--r-- 1 root root    68104 Apr 23 13:53 DISMAN-EVENT-MIB.txt
-rw-r--r-- 1 root root    24613 Apr 23 13:53 DISMAN-SCHEDULE-MIB.txt
-rw-r--r-- 1 root root    64311 Apr 23 13:53 DISMAN-SCRIPT-MIB.txt
-rw-r--r-- 1 root root    84492 Apr 23 13:53 EtherLike-MIB.txt
-rw-r--r-- 1 root root     4660 Apr 23 13:53 HCNUM-TC.txt
-rw-r--r-- 1 root root    52544 Apr 23 13:53 HOST-RESOURCES-MIB.txt
-rw-r--r-- 1 root root    10583 Apr 23 13:53 HOST-RESOURCES-TYPES.txt
-rw-r--r-- 1 root root     4819 Apr 23 13:53 IANA-ADDRESS-FAMILY-NUMBERS-MIB.txt
-rw-r--r-- 1 root root    29665 Apr 23 13:53 IANAifType-MIB.txt
-rw-r--r-- 1 root root     4299 Apr 23 13:53 IANA-LANGUAGE-MIB.txt
-rw-r--r-- 1 root root     3513 Apr 23 13:53 IANA-RTPROTO-MIB.txt
-rw-r--r-- 1 root root     5066 Apr 23 13:53 IF-INVERTED-STACK-MIB.txt
-rw-r--r-- 1 root root    71691 Apr 23 13:53 IF-MIB.txt
-rw-r--r-- 1 root root    16782 Apr 23 13:53 INET-ADDRESS-MIB.txt
-rw-r--r-- 1 root root    46286 Apr 23 13:53 IP-FORWARD-MIB.txt
-rw-r--r-- 1 root root   185667 Apr 23 13:53 IP-MIB.txt
-rw-r--r-- 1 root root    15936 Apr 23 13:53 IPV6-ICMP-MIB.txt
-rw-r--r-- 1 root root    48703 Apr 23 13:53 IPV6-MIB.txt
-rw-r--r-- 1 root root     7257 Apr 23 13:53 IPV6-TCP-MIB.txt
-rw-r--r-- 1 root root     2367 Apr 23 13:53 IPV6-TC.txt
-rw-r--r-- 1 root root     4400 Apr 23 13:53 IPV6-UDP-MIB.txt
-rw-r--r-- 1 root root     5931 Apr 23 13:53 LM-SENSORS-MIB.txt
-rw-r--r-- 1 root root    42375 Apr 23 13:53 MTA-MIB.txt
-rw-rw---- 1 root nagios  19760 Jun 11  2012 NAGIOS-NOTIFY-MIB.txt
-rw-rw---- 1 root nagios   2093 Jun 11  2012 NAGIOS-ROOT-MIB.txt
-rw-r--r-- 1 root root    15732 Apr 23 13:53 NET-SNMP-AGENT-MIB.txt
-rw-r--r-- 1 root root     9160 Apr 23 13:53 NET-SNMP-EXAMPLES-MIB.txt
-rw-r--r-- 1 root root     9198 Apr 23 13:53 NET-SNMP-EXTEND-MIB.txt
-rw-r--r-- 1 root root     2036 Apr 23 13:53 NET-SNMP-MIB.txt
-rw-r--r-- 1 root root     3351 Apr 23 13:53 NET-SNMP-PASS-MIB.txt
-rw-r--r-- 1 root root     4686 Apr 23 13:53 NET-SNMP-TC.txt
-rw-r--r-- 1 root root     5039 Apr 23 13:53 NET-SNMP-VACM-MIB.txt
-rw-r--r-- 1 root root    21006 Apr 23 13:53 NETWORK-SERVICES-MIB.txt
-rw-r--r-- 1 root root    24694 Apr 23 13:53 NOTIFICATION-LOG-MIB.txt
-rw-r--r-- 1 root root     3067 Apr 23 13:53 RFC1155-SMI.txt
-rw-r--r-- 1 root root    79667 Apr 23 13:53 RFC1213-MIB.txt
-rw-r--r-- 1 root root     1174 Apr 23 13:53 RFC-1215.txt
-rw-r--r-- 1 root root   147822 Apr 23 13:53 RMON-MIB.txt
-rw-r--r-- 1 root root    45323 Apr 23 13:53 SCTP-MIB.txt
-rw-r--r-- 1 root root     4595 Apr 23 13:53 SMUX-MIB.txt
-rw-r--r-- 1 root root    15490 Apr 23 13:53 SNMP-COMMUNITY-MIB.txt
-rw-r--r-- 1 root root    22342 Apr 23 13:53 SNMP-FRAMEWORK-MIB.txt
-rw-r--r-- 1 root root     5496 Apr 23 13:53 SNMP-MPD-MIB.txt
-rw-r--r-- 1 root root    20014 Apr 23 13:53 SNMP-NOTIFICATION-MIB.txt
-rw-r--r-- 1 root root     9106 Apr 23 13:53 SNMP-PROXY-MIB.txt
-rw-r--r-- 1 root root    22769 Apr 23 13:53 SNMP-TARGET-MIB.txt
-rw-r--r-- 1 root root    39201 Apr 23 13:53 SNMP-USER-BASED-SM-MIB.txt
-rw-r--r-- 1 root root     2205 Apr 23 13:53 SNMP-USM-AES-MIB.txt
-rw-r--r-- 1 root root    21101 Apr 23 13:53 SNMP-USM-DH-OBJECTS-MIB.txt
-rw-r--r-- 1 root root     8263 Apr 23 13:53 SNMPv2-CONF.txt
-rw-r--r-- 1 root root    29305 Apr 23 13:53 SNMPv2-MIB.txt
-rw-r--r-- 1 root root     8924 Apr 23 13:53 SNMPv2-SMI.txt
-rw-r--r-- 1 root root    38034 Apr 23 13:53 SNMPv2-TC.txt
-rw-r--r-- 1 root root     5775 Apr 23 13:53 SNMPv2-TM.txt
-rw-r--r-- 1 root root    34162 Apr 23 13:53 SNMP-VIEW-BASED-ACM-MIB.txt
-rw-r--r-- 1 root root    28564 Apr 23 13:53 TCP-MIB.txt
-rw-r--r-- 1 root root    16418 Apr 23 13:53 TRANSPORT-ADDRESS-MIB.txt
-rw-r--r-- 1 root root     2163 Apr 23 13:53 UCD-DEMO-MIB.txt
-rw-r--r-- 1 root root     4402 Apr 23 13:53 UCD-DISKIO-MIB.txt
-rw-r--r-- 1 root root     3010 Apr 23 13:53 UCD-DLMOD-MIB.txt
-rw-r--r-- 1 root root     8118 Apr 23 13:53 UCD-IPFWACC-MIB.txt
-rw-r--r-- 1 root root    46150 Apr 23 13:53 UCD-SNMP-MIB.txt
-rw-r--r-- 1 root root    20882 Apr 23 13:53 UDP-MIB.txt
Still no luck.
The MIB I'm trying to install/upload to monitor my HP A5800 switches.
rfc4133-entity-MIB.txt
sreinhardt
-fno-stack-protector
Re: Problem install MIB-Directory permissions may be incorre
Post by sreinhardt »
Just to be certain there are no conflicts, lets modify those permission commands and try them again:
chown -R root:nagios /usr/share/snmp/mibs
chmod -R g+w /usr/share/snmp/mibs
fogier
Post by fogier »
Executed the command, but still same error.
sreinhardt
Could you execute the following command so I can verify the permissions on those files changed properly and that the parent folders are accepting of nagios writing to it. At this point it may appear as though the files have correct permissions, however the mibs directory from your past listing does not seem to allow the nagios group write permission.
ll -R /usr/share/snmp/
What are the permissions now?
Do you see this MIB listed when you go to Admin->Manage MIBs?
Is it in the mibs directory?
ls /usr/share/snmp/mibs/ | grep  rfc4133-entity-MIB.txt
What happens when you copy the file manually to "/usr/share/snmp/mibs/" and run in terminal the following commands?
cd /usr/share/snmp/mibs
chmod chmod 664 rfc4133-entity-MIB.txt
addmib rfc4133-entity-MIB.txt
fogier
Post by fogier »
@sreinhardt
This was before I executed the actions which you colleague suggested.
[root@SERVER ~]# ll -R /usr/share/snmp/
/usr/share/snmp/:
total 288
-rw-r--r--  1 root root  6678 Apr 23 13:53 mib2c.access_functions.conf
-rw-r--r--  1 root root 37814 Apr 23 13:53 mib2c.array-user.conf
-rw-r--r--  1 root root  4705 Apr 23 13:53 mib2c.check_values.conf
-rw-r--r--  1 root root  2527 Apr 23 13:53 mib2c.check_values_local.conf
-rw-r--r--  1 root root   393 Apr 23 13:53 mib2c.column_defines.conf
-rw-r--r--  1 root root   664 Apr 23 13:53 mib2c.column_enums.conf
-rw-r--r--  1 root root   806 Apr 23 13:53 mib2c.column_storage.conf
-rw-r--r--  1 root root 12200 Apr 23 13:53 mib2c.conf
-rw-r--r--  1 root root 28245 Apr 23 13:53 mib2c.container.conf
-rw-r--r--  1 root root  3593 Apr 23 13:53 mib2c.create-dataset.conf
drwxr-xr-x  2 root root  4096 May  8 14:39 mib2c-data
-rw-r--r--  1 root root  8164 Apr 23 13:53 mib2c.emulation.conf
-rw-r--r--  1 root root  8498 Apr 23 13:53 mib2c.genhtml.conf
-rw-r--r--  1 root root  3200 Apr 23 13:53 mib2c.int_watch.conf
-rw-r--r--  1 root root 15279 Apr 23 13:53 mib2c.iterate_access.conf
-rw-r--r--  1 root root 20913 Apr 23 13:53 mib2c.iterate.conf
-rw-r--r--  1 root root  1014 Apr 23 13:53 mib2c.mfd.conf
-rw-r--r--  1 root root  2139 Apr 23 13:53 mib2c.notify.conf
-rw-r--r--  1 root root  9259 Apr 23 13:53 mib2c.old-api.conf
-rw-r--r--  1 root root  8777 Apr 23 13:53 mib2c.perl.conf
-rw-r--r--  1 root root 19507 Apr 23 13:53 mib2c.raw-table.conf
-rw-r--r--  1 root root  7211 Apr 23 13:53 mib2c.row.conf
-rw-r--r--  1 root root  4572 Apr 23 13:53 mib2c.scalar.conf
-rw-r--r--  1 root root 20422 Apr 23 13:53 mib2c.table_data.conf
drwxr-xr-x. 3 root root  4096 May 21 16:30 mibs
drwxr-xr-x. 5 root root  4096 Apr 23 13:53 snmpconf-data
-rw-r--r--  1 root root   145 Apr 23 13:53 snmp_perl.pl
-rw-r--r--  1 root root   431 Apr 23 13:53 snmp_perl_trapd.pl
/usr/share/snmp/mib2c-data:
total 496
-rw-r--r-- 1 root root  4337 Apr 23 13:53 default-mfd-top.m2c
-rw-r--r-- 1 root root  2733 Apr 23 13:53 details-enums.m2i
-rw-r--r-- 1 root root  3520 Apr 23 13:53 details-node.m2i
-rw-r--r-- 1 root root  1083 Apr 23 13:53 details-table.m2i
-rw-r--r-- 1 root root  1088 Apr 23 13:53 generic-ctx-copy.m2i
-rw-r--r-- 1 root root  3610 Apr 23 13:53 generic-ctx-get.m2i
-rw-r--r-- 1 root root  1089 Apr 23 13:53 generic-ctx-set.m2i
-rw-r--r-- 1 root root  1703 Apr 23 13:53 generic-data-allocate.m2i
-rw-r--r-- 1 root root  1606 Apr 23 13:53 generic-data-context.m2i
-rw-r--r-- 1 root root  1647 Apr 23 13:53 generic-get-char.m2i
-rw-r--r-- 1 root root   834 Apr 23 13:53 generic-get-decl-bot.m2i
-rw-r--r-- 1 root root  1519 Apr 23 13:53 generic-get-decl.m2i
-rw-r--r-- 1 root root   597 Apr 23 13:53 generic-get-long.m2i
-rw-r--r-- 1 root root   679 Apr 23 13:53 generic-get-oid.m2i
-rw-r--r-- 1 root root   662 Apr 23 13:53 generic-header-bottom.m2i
-rw-r--r-- 1 root root   681 Apr 23 13:53 generic-header-top.m2i
-rw-r--r-- 1 root root   825 Apr 23 13:53 generic-source-includes.m2i
-rw-r--r-- 1 root root  1619 Apr 23 13:53 generic-table-constants.m2c
-rw-r--r-- 1 root root  1992 Apr 23 13:53 generic-table-enums.m2c
-rw-r--r-- 1 root root  2263 Apr 23 13:53 generic-table-indexes-from-oid.m2i
-rw-r--r-- 1 root root  2296 Apr 23 13:53 generic-table-indexes.m2i
-rw-r--r-- 1 root root  4139 Apr 23 13:53 generic-table-indexes-set.m2i
-rw-r--r-- 1 root root  1754 Apr 23 13:53 generic-table-indexes-to-oid.m2i
-rw-r--r-- 1 root root  1514 Apr 23 13:53 generic-table-indexes-varbind-setup.m2i
-rw-r--r-- 1 root root  3669 Apr 23 13:53 generic-table-oids.m2c
-rw-r--r-- 1 root root  3804 Apr 23 13:53 generic-value-map-func.m2i
-rw-r--r-- 1 root root  1461 Apr 23 13:53 generic-value-map.m2i
-rw-r--r-- 1 root root  1599 Apr 23 13:53 generic-value-map-reverse.m2i
-rw-r--r-- 1 root root  1394 Apr 23 13:53 m2c-internal-warning.m2i
-rw-r--r-- 1 root root  1032 Apr 23 13:53 m2c_setup_enum.m2i
-rw-r--r-- 1 root root 10404 Apr 23 13:53 m2c_setup_node.m2i
-rw-r--r-- 1 root root  1745 Apr 23 13:53 m2c_setup_table.m2i
-rw-r--r-- 1 root root  4541 Apr 23 13:53 m2c_table_save_defaults.m2i
-rw-r--r-- 1 root root 17717 Apr 23 13:53 mfd-access-container-cached-defines.m2i
-rw-r--r-- 1 root root 41111 Apr 23 13:53 mfd-access-unsorted-external-defines.m2i
-rw-r--r-- 1 root root 10740 Apr 23 13:53 mfd-data-access.m2c
-rw-r--r-- 1 root root  5211 Apr 23 13:53 mfd-data-get.m2c
-rw-r--r-- 1 root root  5053 Apr 23 13:53 mfd-data-set.m2c
-rw-r--r-- 1 root root  2435 Apr 23 13:53 mfd-doxygen.m2c
-rw-r--r-- 1 root root 11993 Apr 23 13:53 mfd-interactive-setup.m2c
-rw-r--r-- 1 root root 51954 Apr 23 13:53 mfd-interface.m2c
-rw-r--r-- 1 root root  4186 Apr 23 13:53 mfd-makefile.m2m
-rw-r--r-- 1 root root 15367 Apr 23 13:53 mfd-persistence.m2i
-rw-r--r-- 1 root root 30521 Apr 23 13:53 mfd-readme.m2c
-rw-r--r-- 1 root root 17600 Apr 23 13:53 mfd-top.m2c
-rw-r--r-- 1 root root  3776 Apr 23 13:53 node-get.m2i
-rw-r--r-- 1 root root  7793 Apr 23 13:53 node-set.m2i
-rw-r--r-- 1 root root   730 Apr 23 13:53 node-storage.m2i
-rw-r--r-- 1 root root  2419 Apr 23 13:53 node-validate.m2i
-rw-r--r-- 1 root root  2140 Apr 23 13:53 node-varbind-validate.m2i
-rw-r--r-- 1 root root  2010 Apr 23 13:53 parent-dependencies.m2i
-rw-r--r-- 1 root root 14661 Apr 23 13:53 parent-set.m2i
-rw-r--r-- 1 root root  5944 Apr 23 13:53 subagent.m2c
-rw-r--r-- 1 root root  1235 Apr 23 13:53 syntax-COUNTER64-get.m2i
-rw-r--r-- 1 root root   319 Apr 23 13:53 syntax-DateAndTime-get.m2d
-rw-r--r-- 1 root root  2200 Apr 23 13:53 syntax-DateAndTime-get.m2i
-rw-r--r-- 1 root root   288 Apr 23 13:53 syntax-DateAndTime-readme.m2i
-rw-r--r-- 1 root root  3032 Apr 23 13:53 syntax-InetAddress-get.m2i
-rw-r--r-- 1 root root   924 Apr 23 13:53 syntax-InetAddress-set.m2i
-rw-r--r-- 1 root root  1051 Apr 23 13:53 syntax-InetAddressType-get.m2i
-rw-r--r-- 1 root root  1009 Apr 23 13:53 syntax-InetAddressType-set.m2i
-rw-r--r-- 1 root root  4250 Apr 23 13:53 syntax-RowStatus-dependencies.m2i
-rw-r--r-- 1 root root  2484 Apr 23 13:53 syntax-RowStatus-get.m2i
-rw-r--r-- 1 root root   661 Apr 23 13:53 syntax-RowStatus-varbind-validate.m2i
-rw-r--r-- 1 root root   777 Apr 23 13:53 syntax-StorageType-dependencies.m2i
-rw-r--r-- 1 root root   828 Apr 23 13:53 syntax-TestAndIncr-get.m2i
/usr/share/snmp/mibs:
total 1996
-rw-r--r-- 1 root   root   114882 May 21 16:25 MCAFEE-SCM-MIB.txt
drwxr-xr-x 2 apache apache   4096 Mar 27 15:51 processed_mibs
-rw-r--r-- 1 root   root    59144 Dec  9  2009 rfc4133-entity-MIB.txt
-rw-r--r-- 1 root   root     4655 May 21 14:04 TM-HWMONITOR-MIB.txt
-rw-rw-r-- 1 apache apache    276 Mar 27 15:51 TRAP-TEST-MIB.txt
-rw-r--r-- 1 root   root     7104 May 21 14:04 TREND-IWSS-MIB-SNMPv2.txt
/usr/share/snmp/mibs/processed_mibs:
total 4
-rw-r--r-- 1 apache apache 304 Mar 27 15:51 TRAP-TEST-MIB.txt
/usr/share/snmp/snmpconf-data:
total 12
drwxr-xr-x. 2 root root 4096 May  8 14:39 snmp-data
drwxr-xr-x. 2 root root 4096 May  8 14:39 snmpd-data
drwxr-xr-x. 2 root root 4096 May  8 14:39 snmptrapd-data
/usr/share/snmp/snmpconf-data/snmp-data:
total 20
-rw-r--r-- 1 root root 2839 Apr 23 13:53 authopts
-rw-r--r-- 1 root root 1639 Apr 23 13:53 debugging
-rw-r--r-- 1 root root 2207 Apr 23 13:53 mibs
-rw-r--r-- 1 root root 3089 Apr 23 13:53 output
-rw-r--r-- 1 root root   23 Apr 23 13:53 snmpconf-config
/usr/share/snmp/snmpconf-data/snmpd-data:
total 32
-rw-r--r-- 1 root root 1628 Apr 23 13:53 acl
-rw-r--r-- 1 root root 1013 Apr 23 13:53 basic_setup
-rw-r--r-- 1 root root 2758 Apr 23 13:53 extending
-rw-r--r-- 1 root root 3252 Apr 23 13:53 monitor
-rw-r--r-- 1 root root 1311 Apr 23 13:53 operation
-rw-r--r-- 1 root root   24 Apr 23 13:53 snmpconf-config
-rw-r--r-- 1 root root 1852 Apr 23 13:53 system
-rw-r--r-- 1 root root 1751 Apr 23 13:53 trapsinks
/usr/share/snmp/snmpconf-data/snmptrapd-data:
total 24
-rw-r--r-- 1 root root 285 Apr 23 13:53 authentication
-rw-r--r-- 1 root root 652 Apr 23 13:53 formatting
-rw-r--r-- 1 root root 827 Apr 23 13:53 logging
-rw-r--r-- 1 root root 351 Apr 23 13:53 runtime
-rw-r--r-- 1 root root  28 Apr 23 13:53 snmpconf-config
-rw-r--r-- 1 root root 888 Apr 23 13:53 traphandle
fogier
Post by fogier »
@lmiltchev
See the post above for the permissions.
I've copied the mib file (sftp) to the Nagios-server and executed:
Result:
[root@SERVER mibs]# ls -l | grep rfc4133
-rw-rw-r-- 1 root   root    59144 Dec  9  2009 rfc4133-entity-MIB.txt
I can now see it in the Admin-Manage MIBs website. However, I still cannot upload it via the webpage. Strange, since this is a downloaded vSphere template from your website. No alterations are made in this directories. Just starting with SNMP.
sreinhardt
I understand that you had listed them before, we would like to see them AFTER you applied the changes just to be sure they everything looks good. So if you could please run a listing on that directory again it would be appreciated. Also could you also please run the rest of lmiltchev's commands. We as for information multiple times after changing it to verify everything is correct.
fogier
Post by fogier »
No problem. All commands were executed and this is the result:
[root@SERVER ~]# ls -ld /usr/share/snmp
drwxr-xr-x. 5 root root 4096 May  8 14:39 /usr/share/snmp
[root@SERVER ~]# ls -ld /usr/share/snmp/mibs
drwxr-xr-x. 3 root root 4096 May 23 07:30 /usr/share/snmp/mibs
[root@SERVER ~]# ll /usr/share/snmp/mibs
total 1880
sreinhardt
The permissions still don't look right. Run the following and post the output back please.
chown -R root.nagios /usr/share/snmp/mibs
ll -d /usr/share/snmp/
ll -d /usr/share/snmp/mibs
