Is this something normal while executing ./E-importnagiosql?
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies
http://localhost/nagiosql/admin/verify.php --post-data 'writeAdditional=Go' -O nagiosql.export.additional
OUTPUT:
Nagios Core 3.2.2
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 09-01-2010
License: GPL
Website:
http://www.nagios.org
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Error: Cannot open config file '/usr/local/nagios/etc/contacttemplates.cfg' for reading: No such file or directory
RET: 254
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors ~/nagios/nagiosxi/nagiosxi/basedir/scripts
tar: Removing leading `/' from member names
ls: /usr/local/nagiosxi/nom/checkpoints/nagioscore/*.gz: No such file or directory
NO NOM SNAPSHOT FOUND!
~/nagios/nagiosxi
