unable to start Nagios service
ericsson_att
Post by ericsson_att »
We are in the process of evaluating Nagios XI.
We successfully ran the manual installation for Nagios XI on CentOS 5.5
However, we are unable to start the Nagios server. Error given below.
[root@ltenav1 etc]# service nagios start
Starting nagios:CONFIG ERROR! Start aborted. Check your Nagios configuration.
You have new mail in /var/spool/mail/root
admin
Site Admin
Re: unable to start Nagios service
Post by admin »
What does the output of the following command indicate?
Ethan Galstad
President
ericsson_att
[root@ltenav1 etc]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 3.2.2
Copyright (c) 2009-2010 Nagios Core Development Team and Community Contributors
Last Modified: 09-01-2010
License: GPL
Reading configuration data...
Read main config file okay...
Processing object config directory '/usr/local/nagios/etc/static'...
Processing object config file '/usr/local/nagios/etc/static/xitemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xitest.cfg'...
Processing object config file '/usr/local/nagios/etc/static/xiobjects.cfg'...
Processing object config file '/usr/local/nagios/etc/contacttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/contactgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/hostgroups.cfg'...
Processing object config file '/usr/local/nagios/etc/servicegroups.cfg'...
Processing object config file '/usr/local/nagios/etc/hosttemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicetemplates.cfg'...
Processing object config file '/usr/local/nagios/etc/servicedependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostdependencies.cfg'...
Processing object config file '/usr/local/nagios/etc/hostescalations.cfg'...
Processing object config file '/usr/local/nagios/etc/hostextinfo.cfg'...
Processing object config file '/usr/local/nagios/etc/serviceextinfo.cfg'...
Processing object config directory '/usr/local/nagios/etc/hosts'...
Processing object config directory '/usr/local/nagios/etc/services'...
Checking services...
Error: There are no services defined!
Checked 0 services.
Checking hosts...
Error: There are no hosts defined!
Checked 0 hosts.
Checking host groups...
Checked 0 host groups.
Checking service groups...
Checked 0 service groups.
Checking contacts...
Error: Service notification command 'xi_service_notification_handler' specified for contact 'xi_default_contact' is not defined anywhere!
Error: Host notification command 'xi_host_notification_handler' specified for contact 'xi_default_contact' is not defined anywhere!
Checked 1 contacts.
Checking contact groups...
Checked 0 contact groups.
Checking service escalations...
Checking service dependencies...
Checked 0 service dependencies.
Checking host escalations...
Checked 0 host escalations.
Checking host dependencies...
Checked 0 host dependencies.
Checking commands...
Checked 0 commands.
Checking time periods...
Checked 2 time periods.
Checking for circular paths between hosts...
Checking for circular host and service dependencies...
Error: Global host event handler command 'xi_host_event_handler' is not defined anywhere!
Error: Global service event handler command 'xi_service_event_handler' is not defined anywhere!
Checking misc settings...
Total Warnings: 0
Total Errors: 6
***> One or more problems was encountered while running the pre-flight check...
[root@ltenav1 etc]#
admin
Site Admin
Post by admin »
It sounds like the default object definitions didn't get setup properly. Did you go through all the commands outlines in the manual installation document?
Also, are you running or using any type of proxy software on this server?
Ethan Galstad
President
ericsson_att
We did go through all the commands (./0-yum until ./Z-webroot) outlines in the manual installation document.
Yes we are behind proxy server. Accordingly, we did update the following-
In /etc/yum.conf :
proxy=http://someproxyserver:port/
In /etc/wgetrc :
http_proxy=http://someproxyserver:port/
no_proxy=localhost,127.0.0.0/8,10.0.0.0/8,172.16.0.0/12,192.168.0.0/16
Only then, it started to install all packages/rpm's.
ericsson_att
After a fresh installation, are we expected to update the nagios.cfg file. If yes, then could you please send us a sample nagios.cfg file. There is no information on this in the Manual Installation Document.
admin
Site Admin
Post by admin »
Did you re-run all the scripts after configuring things for your proxy?
In particular, it sounds like the configure import failed. This is accomplished with scripts that issue wgets to localhost. These scripts are kicked off by the following step in the install:
./E-importnagiosql
You might be able to just re-run that particular command to get things imported.
Ethan Galstad
President
ericsson_att
We don't see an issue with it... but here are the logs for you to trace ....
]0;root@ltenav1:~/nagios/nagiosxi[root@ltenav1 nagiosxi]# ./E-importnagiosql
Starting httpd:
~/nagios/nagiosxi/nagiosxi/basedir/scripts ~/nagios/nagiosxi
PHP Warning: pg_connect(): Unable to connect to PostgreSQL server: FATAL: database "nagiosxi" does not exist in /root/nagios/nagiosxi/nagiosxi/basedir/html/db/adodb/drivers/adodb-postgres64.inc.php on line 686
DB Connect Error [nagiosxi]: Database connection failed
ERROR CONNECTING TO DATABASES!
IMPORTING CONFIG FILES...Array
[0] => commands.cfg
[1] => contacts.cfg
[2] => localhost.cfg
[3] => nagiosadmin.cfg
[4] => templates.cfg
[5] => timeperiods.cfg
[6] => xicommands.cfg
[7] => xiobjects.cfg
[8] => xitemplates.cfg
[9] => xiwzardtemplates.cfg
IMPORTING /usr/local/nagios/etc/import/commands.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/commands.cfg' -O nagiosql.import.monitoring
--2010-11-03 13:28:36-- http://localhost/nagiosql/admin/import.php
Resolving localhost... 127.0.0.1
Connecting to localhost|127.0.0.1|:80... connected.
Length: 0 [text/html]
Saving to: `nagiosql.import.monitoring'
[<=> ] 0 --.-K/s
[ <=> ] 0 --.-K/s in 0s
2010-11-03 13:28:36 (0.00 B/s) - `nagiosql.import.monitoring' saved [0/0]
IMPORTING /usr/local/nagios/etc/import/contacts.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/contacts.cfg' -O nagiosql.import.monitoring
[<=> ] 0 --.-K/s
IMPORTING /usr/local/nagios/etc/import/localhost.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/localhost.cfg' -O nagiosql.import.monitoring
[<=> ] 0 --.-K/s
IMPORTING /usr/local/nagios/etc/import/nagiosadmin.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/nagiosadmin.cfg' -O nagiosql.import.monitoring
[<=> ] 0 --.-K/s
IMPORTING /usr/local/nagios/etc/import/templates.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/templates.cfg' -O nagiosql.import.monitoring
[<=> ] 0 --.-K/s
2010-11-03 13:28:37 (0.00 B/s) - `nagiosql.import.monitoring' saved [0/0]
IMPORTING /usr/local/nagios/etc/import/timeperiods.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/timeperiods.cfg' -O nagiosql.import.monitoring
--2010-11-03 13:28:37-- http://localhost/nagiosql/admin/import.php
[<=> ] 0 --.-K/s
IMPORTING /usr/local/nagios/etc/import/xicommands.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/xicommands.cfg' -O nagiosql.import.monitoring
[<=> ] 0 --.-K/s
IMPORTING /usr/local/nagios/etc/import/xiobjects.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/xiobjects.cfg' -O nagiosql.import.monitoring
[<=> ] 0 --.-K/s
IMPORTING /usr/local/nagios/etc/import/xitemplates.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/xitemplates.cfg' -O nagiosql.import.monitoring
[<=> ] 0 --.-K/s
IMPORTING /usr/local/nagios/etc/import/xiwzardtemplates.cfg
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/import.php --post-data 'chbOverwrite=1&selImportFile[]=/usr/local/nagios/etc/import/xiwzardtemplates.cfg' -O nagiosql.import.monitoring
[<=> ] 0 --.-K/s
SETUID ROOT OK
RESETTING PERMS
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --post-data 'writeMonitoring=Go' -O nagiosql.export.monitoring
--2010-11-03 13:28:37-- http://localhost/nagiosql/admin/verify.php
Saving to: `nagiosql.export.monitoring'
[<=> ] 0 --.-K/s
2010-11-03 13:28:37 (0.00 B/s) - `nagiosql.export.monitoring' saved [0/0]
Saving to: `nagiosql.export.additional'
[<=> ] 0 --.-K/s
2010-11-03 13:28:38 (0.00 B/s) - `nagiosql.export.additional' saved [0/0]
CMDLINE:
/usr/bin/wget --load-cookies=nagiosql.cookies http://localhost/nagiosql/admin/verify.php --post-data 'writeAdditional=Go' -O nagiosql.export.additional
OUTPUT:
Nagios Core 3.2.2
License: GPL
Error: Cannot open config file '/usr/local/nagios/etc/contacttemplates.cfg' for reading: No such file or directory
RET: 254
/usr/local/nagiosxi/nom/checkpoints/nagioscore/errors ~/nagios/nagiosxi/nagiosxi/basedir/scripts
tar: Removing leading `/' from member names
ls: /usr/local/nagiosxi/nom/checkpoints/nagioscore/*.gz: No such file or directory
NO NOM SNAPSHOT FOUND!
~/nagios/nagiosxi
mguthrie
Post by mguthrie »
I'm noticing there may have been some problems with postgresql installing or starting correctly. Check the following:
service postgresql status
service postgresql restart
If it's not installed then I'm guessing that had an issue with the proxy. See if you can get it installed if it isn't there already, then try running through the install scripts again.
ericsson_att
Since the db_servertype=mysql in ndo2db.cfg, shouldnt Nagios use MySQL DB? Does nagios require both Postgress and MySQL?
Anyways,here is the status from the commands:
[root@ltenav1 etc]# service postgresql status
postmaster (pid 9172 9171 9170 9164 9105) is running...
[root@ltenav1 etc]# service postgresql restart
Stopping postgresql service: [ OK ]
Starting postgresql service: [ OK ]
[root@ltenav1 etc]#
