This support forum board is for support questions relating to
Nagios XI , our flagship commercial network monitoring solution.
sarfarosh
Posts: 211 Joined: Fri Oct 05, 2012 3:56 am
Post
by sarfarosh » Tue Jun 25, 2013 5:25 am
I have successfully upgraded Nagios xi to 2012 r2.2, but this don't seem to work, Still getting same error as in r1.8 with
Bandwidth & Reports
All the process of nagiosxi are also working perfectly
/usr/local/nagios/var/perfdata.log says :-
[root@nagios155 ~]# tail -f /usr/local/nagios/var/perfdata.log
2013-06-25 15:42:30 [3529] [0] *** TIMEOUT: Please check your npcd.cfg
2013-06-25 15:42:30 [3529] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1372155125-PID-3529 deleted
2013-06-25 15:42:30 [3529] [0] *** Timeout while processing Host: "BHIL-TRNK-SHEETAL-GIG-49" Service: "GigabitEthernet1010"
2013-06-25 15:42:30 [3529] [0] *** process_perfdata.pl terminated on signal ALRM
2013-06-25 15:44:59 [14202] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-06-25 15:44:59 [14202] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-06-25 15:44:59 [14202] [0] *** TIMEOUT: Please check your npcd.cfg
2013-06-25 15:44:59 [14202] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//host-perfdata.1372155280-PID-14202 deleted
2013-06-25 15:44:59 [14202] [0] *** Timeout while processing Host: "BHIL-4-BSMKTH-BABUKHAN-200.138" Service: "_HOST_"
2013-06-25 15:44:59 [14202] [0] *** process_perfdata.pl terminated on signal ALRM
2013-06-25 15:52:45 [18522] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-06-25 15:52:45 [18522] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-06-25 15:52:45 [18522] [0] *** TIMEOUT: Please check your npcd.cfg
2013-06-25 15:52:45 [18522] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1372155740-PID-18522 deleted
2013-06-25 15:52:45 [18522] [0] *** Timeout while processing Host: "BHIL-4-PANJAG-NIMS-200.91" Service: "fastethernet1023"
2013-06-25 15:52:45 [18522] [0] *** process_perfdata.pl terminated on signal ALRM
and NPCD.log say:
[05-10-2013 14:59:59] NPCD: npcd Daemon (0.4.14) started with PID=28852
[05-10-2013 14:59:59] NPCD: Please have a look at 'npcd -V' to get license information
[05-10-2013 14:59:59] NPCD: HINT: load_threshold is enabled - ('10.000000')
[05-10-2013 16:14:04] NPCD: WARN: MAX load reached: load 10.210000/10.000000 at i=0[05-10-2013 16:22:43] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:22:43] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368183141.perfdata.service'
[05-10-2013 16:25:52] NPCD: WARN: MAX load reached: load 11.600000/10.000000 at i=0[05-10-2013 16:26:07] NPCD: WARN: MAX load reached: load 13.510000/10.000000 at i=1[05-10-2013 16:26:22] NPCD: WARN: MAX load reached: load 11.060000/10.000000 at i=1[05-10-2013 16:26:42] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:26:42] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368183341.perfdata.service'
[05-10-2013 16:26:42] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368183342.perfdata.host'
[05-10-2013 16:27:02] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:27:02] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368183356.perfdata.service'
[05-10-2013 16:27:03] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:27:03] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368183356.perfdata.host'
[05-10-2013 16:27:23] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:27:23] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368183426.perfdata.service'
[05-10-2013 16:28:13] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:28:13] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368183464.perfdata.service'
[05-10-2013 16:28:50] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:28:50] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368183510.perfdata.service'
[05-10-2013 16:29:10] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:29:10] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368183528.perfdata.service'
[05-10-2013 16:32:14] NPCD: WARN: MAX load reached: load 10.270000/10.000000 at i=0[05-10-2013 16:34:46] NPCD: WARN: MAX load reached: load 10.220000/10.000000 at i=0[05-10-2013 16:36:50] NPCD: WARN: MAX load reached: load 10.660000/10.000000 at i=0[05-10-2013 16:37:20] NPCD: WARN: MAX load reached: load 10.630000/10.000000 at i=0[05-10-2013 16:37:35] NPCD: WARN: MAX load reached: load 10.480000/10.000000 at i=1[05-10-2013 16:37:50] NPCD: WARN: MAX load reached: load 14.040000/10.000000 at i=1[05-10-2013 16:38:05] NPCD: WARN: MAX load reached: load 11.760000/10.000000 at i=1[05-10-2013 16:38:20] NPCD: WARN: MAX load reached: load 14.310000/10.000000 at i=1[05-10-2013 16:38:35] NPCD: WARN: MAX load reached: load 11.560000/10.000000 at i=1[05-10-2013 16:39:14] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:39:14] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368184058.perfdata.service'
[05-10-2013 16:39:14] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368184085.perfdata.service'
[05-10-2013 16:40:07] NPCD: WARN: MAX load reached: load 12.450000/10.000000 at i=0[05-10-2013 16:40:22] NPCD: WARN: MAX load reached: load 10.340000/10.000000 at i=1[05-10-2013 16:40:57] NPCD: WARN: MAX load reached: load 10.870000/10.000000 at i=0[05-10-2013 16:41:17] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:41:17] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368184235.perfdata.service'
[05-10-2013 16:41:38] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:41:38] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368184287.perfdata.service'
[05-10-2013 16:43:02] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:43:02] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368184371.perfdata.service'
[05-10-2013 16:44:08] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:44:08] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368184431.perfdata.service'
[05-10-2013 16:49:06] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:49:06] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368184732.perfdata.service'
[05-10-2013 16:49:21] NPCD: WARN: MAX load reached: load 11.270000/10.000000 at i=0[05-10-2013 16:51:42] NPCD: WARN: MAX load reached: load 10.130000/10.000000 at i=0[05-10-2013 16:52:02] NPCD: ERROR: Executed command exits with return code '7'
[05-10-2013 16:52:02] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//1368184884.perfdata.service'
[05-10-2013 16:52:54] NPCD: ERROR: Executed command exits with return code '7'
Posts: 7698 Joined: Mon Apr 23, 2012 4:28 pm
Post
by slansing » Tue Jun 25, 2013 9:28 am
Looks like NPCD is not processing the check results, lets increase the timeout and load:
vi /usr/local/nagios/etc/pnp/process_perfdata.cfg
Change:
To:
Also edit this file:
vi /usr/local/nagios/etc/pnp/npcd.cfg
Change:
To:
service npcd stop
killall -9 npcd
service npcd start
wait about 10 minutes and then tail the logs above again and post the output here.
sarfarosh
Post
by sarfarosh » Tue Jun 25, 2013 1:22 pm
Slansing
after the changes npcd error seems to have gone below is the output of npcd.log
[root@nagios155 ~]# tail -f /usr/local/nagios/var/npcd.log
[06-25-2013 18:26:29] NPCD: ERROR: Executed command exits with return code '7'
[06-25-2013 18:26:29] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//service-perfdata.1372164973'
[06-25-2013 20:25:21] NPCD: ERROR: Executed command exits with return code '7'
[06-25-2013 20:25:21] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//service-perfdata.1372172113'
[06-25-2013 21:30:20] NPCD: ERROR: Executed command exits with return code '7'
[06-25-2013 21:30:20] NPCD: ERROR: Command line was '/usr/local/nagios/libexec/process_perfdata.pl -n -b /usr/local/nagios/var/spool/perfdata//service-perfdata.1372175998'
[06-25-2013 21:54:44] NPCD: Caught Termination Signal - Hasta la vista... baby
[06-25-2013 21:55:20] NPCD: npcd Daemon (0.4.14) started with PID=3193
[06-25-2013 21:55:20] NPCD: Please have a look at 'npcd -V' to get license information
[06-25-2013 21:55:20] NPCD: HINT: load_threshold is enabled - ('40.000000')
but prefdata has below error
[root@nagios155 ~]# tail -f 200 /usr/local/nagios/var/perfdata.log
tail: cannot open `200' for reading: No such file or directory
==> /usr/local/nagios/var/perfdata.log <==
2013-06-25 20:25:21 [13748] [0] *** TIMEOUT: Please check your npcd.cfg
2013-06-25 20:25:21 [13748] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1372172113-PID-13748 deleted
2013-06-25 20:25:21 [13748] [0] *** Timeout while processing Host: "BHIL-4-BSMKTH-SUPRAJ-202.8" Service: "fastethernet1016"
2013-06-25 20:25:21 [13748] [0] *** process_perfdata.pl terminated on signal ALRM
2013-06-25 21:30:20 [13764] [0] *** TIMEOUT: Timeout after 5 secs. ***
2013-06-25 21:30:20 [13764] [0] *** TIMEOUT: Deleting current file to avoid NPCD loops
2013-06-25 21:30:20 [13764] [0] *** TIMEOUT: Please check your npcd.cfg
2013-06-25 21:30:20 [13764] [0] *** TIMEOUT: /usr/local/nagios/var/spool/perfdata//service-perfdata.1372175998-PID-13764 deleted
2013-06-25 21:30:20 [13764] [0] *** Timeout while processing Host: "BHIL-4-1LANCR-IRFAN-200.168" Service: "fastethernet1017"
2013-06-25 21:30:20 [13764] [0] *** process_perfdata.pl terminated on signal ALRM
Below is mine process_perfdata.cfg content
# Config File for process_perfdata.pl
# $Id: process_perfdata.cfg-sample.in 520 2008-09-16 12:50:10Z pitchfork $
# process_perfdata.pl Timout
TIMEOUT = 20
# Use RRDs Perl Module
USE_RRDs = 1
RRDPATH = /usr/local/nagios/share/perfdata
RRDTOOL = /usr/bin/rrdtool
CFG_DIR = /usr/local/nagios/etc/pnp
RRD_HEARTBEAT = 8460
RRA_CFG = /usr/local/nagios/etc/pnp/rra.cfg
RRA_STEP = 60
LOG_FILE = /usr/local/nagios/var/perfdata.log
# Loglevel 0=silent 1=normal 2=debug
LOG_LEVEL = 0
# XML encoding
# The supported encodings are ISO-8859-1, UTF-8 and US-ASCII.
# http://www.php.net/xml-parser-create
XML_ENC = UTF-8
# EXPERIMENTAL rrdcached Support
# Use only with rrdtool svn revision 1511+
# RRD_DAEMON_OPTS = unix:/tmp/rrdcached.sock
Still we are facing Bandwidth & Report Error
Post
by slansing » Tue Jun 25, 2013 1:34 pm
Did you restart NPCD after the changes were made?
Also please post the result of the following:
ll /usr/local/nagios/share/perfdata
Also, it looks like that perfdata.log tail in the second code section was taken before the npcd.log, can you verify that it is still giving you that error at the current time? Be sure to check the timestamp and verify it against your true real time, right now.
Are the graphs loading at all? Or are they displaying some sort of error?
sarfarosh
Post
by sarfarosh » Tue Jun 25, 2013 1:48 pm
slansing wrote: Did you restart NPCD after the changes were made?
I had restarted NPCD
Below is the ll output
root@nagios155 ~]# ll /usr/local/nagios/share/perfdata
total 1892
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 10.1.1.2
drwxrwxr-x 2 nagios nagios 4096 Jun 18 17:56 123.176.37.9
drwxrwxr-x 2 nagios nagios 4096 Jun 25 15:03 172.16.200.156
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 172.16.201.11
drwxrwxr-x 2 nagios nagios 4096 Jun 25 15:03 172.17.241.11
drwxrwxr-x 2 nagios nagios 4096 Jun 25 15:03 172.17.241.72
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 172.17.241.9
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 ANH2
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 ANR-BEAM-OFFICE
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 APEX
drwxrwxr-x 2 nagios nagios 4096 Jun 18 17:59 BANJARA
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 BBLOCK
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-ANANDRES-200.199
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-1LANCR-APRICSCH-201.152
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-ESHWAR-200.160
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-1LANCR-GARDENTW-200.183
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-HASAM-200.161
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-1LANCR-HUSSAIN-201.151
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-1LANCR-IQRA-200.198
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-1LANCR-IRFAN-200.168
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-1LANCR-JUBLEEST-200.172
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-JUNASUBA-200.173
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-1LANCR-MOIZ-202.45
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-MOONROCK-200.164
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-MUJEEB-202.46
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-1LANCR-RAMAIAH-201.154
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-RATNAVIL-200.156
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-ROSENCL-200.193
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-1LANCR-SIDULLAH-200.185
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-SIRAJ-200.166
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-1LANCR-SOCTYGAR-200.174
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-1LANCR-UNITDRES-200.169
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-VASUDHA-200.175
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LANCR-YOUSUF-201.153
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LNCR-ABDLHAFZ-201.157
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-1LNCR-MHESHWRI-201.156
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-1LNCR-VNKTNRYNA-201.159
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-AKBAR-201.251
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-ANHBONU-201.201
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-APEX-200.210
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-ASHIYANA-200.209
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-BATTLANE-201.204
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-BAZARGHA-200.216
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-BRINDAVN-200.250
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-NASAR-200.252
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-SBIBANK-201.210
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-VIJYHILS-200.201
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-ACGARD-WESTPRK-200.223
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-AGHAPURA-200.208
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-BALAJI-201.214
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-BHOIGUDA-200.222
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-CHARDEEL-201.206
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-CHOTARAD-201.213
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-COLOUR-200.244
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-DMRESI-200.245
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-GEMINI-202.44
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-GODEKAKA-201.247
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-HABEBNGR-201.254
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-JALIHANU-200.254
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-MANSR-201.216
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-MIRZA-200.229
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-MNGLHTPS-200.242
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-AGAPUR-NMZGRND-200.215
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGAPUR-ORIENTAL-200.228
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGAPUR-PUNIT-200.247
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGAPUR-ROCKTGRD-200.240
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGAPUR-SITRMBGH-200.214
drwxrwxr-x 2 nagios nagios 4096 Jun 25 23:57 BHIL-4-AGAPUR-SRISHYAM-200.241
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGAPUR-TVSASSOC-200.239
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGAPUR-WELCOME-200.236
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGAPUR-YADAV-201.202
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGHAPR-ANITWR-201.238
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGHAPR-MRKT-201.239
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-AGHAPR-SVLALNGR-201.237
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-AKAGANAP-202.6
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-ANANDNGR-200.16
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-ASHOKKMR-200.77
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-KALYAN-200.13
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-ANDNAG-MAHESHTW-202.31
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-MROOFF-200.99
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-MUPATWRS-200.58
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-PREMNGR-200.18
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-RAGVREDD-202.38
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-REMO-200.54
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-ROYMAJES-202.32
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-SHANNIVA-202.30
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:01 BHIL-4-ANDNAG-SRINIAPT-202.51
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-SRISAIAP-200.30
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:05 BHIL-4-ANDNAG-TELANGAN-200.17
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-UDYTULSI-200.14
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ANDNAG-ZPOFFICE-200.59
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ASIFNG-AZIZBAG-201.203
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ASIFNG-BHAITAK-200.232
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ASIFNG-DHANRAJ-202.43
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ASIFNG-FIROZGAN-200.227
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ASIFNG-HASAN-202.14
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ASIFNG-ITHIGRND-202.42
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ASIFNG-SHANTKRN-200.248
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ASIFNG-SRIKUMRP-200.205
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ASIFNG-ZUBEDMAS-202.40
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BAJH1-TRVNSNGM-201.1
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BAJH2-ASMA-202.236
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BAJH2-KAMMAN-201.155
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BAJH2-KUBMSJD-201.158
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BAJH3-PATEL-201.161
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BAJH3-SUBAREDY-201.160
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BAJH4-GURUBMNGR-202.234
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BAJH4-HNGNGRDN-200.79
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BAJH4-LAVILLA-202.235
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ11-ACHYUTHA-200.47
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BANJ14-AMBEDKAR-200.69
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:02 BHIL-4-BANJ14-CASALUXY-202.16
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-CROSWING-200.60
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-FARHAN-200.31
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BANJ14-KHAN-202.20
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BANJ14-LAKSHYUN-200.66
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-MTBANJAR-200.64
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-NANDINGR-200.44
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-OLESHOW-201.13
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-PAVANEST-200.52
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BANJ14-PS-200.21
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-STONVLEY-200.56
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-SURABI-200.22
drwxrwxr-x 2 nagios nagios 4096 Jun 25 23:57 BHIL-4-BANJ14-SVNAGAR-200.27
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-TARUN-200.39
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-TCA-200.46
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-TRENDSET-202.26
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BANJ14-TV9-200.75
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BANJ14-VIDIAPT-200.33
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BANJ14-ZAIKARES-201.243
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-APARNACH-200.45
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-ASIFZAHI-202.22
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-ATLAS-200.25
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BJ1011-AYUBHUSE-200.20
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-CENTRIX-200.19
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BJ1011-CRAFTHSE-201.252
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-CREACTLE-200.35
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-GSCOLONY-200.67
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-IBRMHIM-200.51
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-JUDGQTRS-200.26
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-LAKEVIEW-200.63
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BJ1011-MENAKSHI-200.23
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-NOORNGAR-200.72
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-PRKINGOF-200.28
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BJ1011-SAIRAJNV-200.36
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-SINGABAS-200.65
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-STARHOSP-200.73
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-STORES-200.68
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-TVKRESID-201.5
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-VEERENDR-200.49
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1011-ZEHRANGR-200.61
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ114-AKBAR-202.25
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BJ1-14-AKTOWERS-201.9
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-AZAAN-200.55
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BJ1-14-BASHVILL-202.23
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-JOURNCLY-200.41
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-KRISHMAN-_201.12
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BJ1-14-KRISHNPT-200.48
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-MERIDSCH-200.74
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-MOHDHBIB-200.40
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-MOUNTMER-200.29
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-NAGARJNA-200.37
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:05 BHIL-4-BJ1-14-PANCVATI-202.50
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-PARKSIDE-200.50
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-QMART-200.78
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-SAGASOCI-200.43
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-SHABAZ-200.53
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-SHEETAL-200.62
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BJ1-14-SHILPARK-202.58
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-SMDVLLEY-200.32
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-SORAYA-200.71
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-SRUJANA-200.70
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BJ1-14-SYNDBANK-202.24
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1-14-WAJID-200.38
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1213-AMURVALL-200.176
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BJ1213-ANANDBNJ-200.165
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BJ1213-AXIOM200.153
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BJ1213-BANJGARD200.152
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BJ1213-BUCKGHAM-202.19
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1213-DECCAN-200.195
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-BJ1213-FORTENCL-200.163
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1213-GOVTSCHL-200.158
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-BJ1213-JAGADISH-202.36
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BJ1213-KEMTISQU-200.191
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1213-MAHIREDD-202.47
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1213-MITHLNGR-200.167
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-BJ1213-SAIENCLA-200.184
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-BJ1213-SPANVLEY-200.180
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1213-VENKTESH-202.56
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJ1213-VIJYBNK-200.196
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BJRD10-YAWER-202.18
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BJRD14-MOHSIN-202.233
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BSMKTH-A12BUILD-200.136
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BSMKTH-AYYAPTEM-200.111
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BSMKTH-BABUKHAN-200.138
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BSMKTH-BSMAKTH1-200.89
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BSMKTH-BSMAKTHA-200.83
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-BSMKTH-LAKMALAP-202.27
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BSMKTH-RAINTWRS-200.103
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-BSMKTH-RAKQYA-200.129
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BSMKTH-SHANSHIK-200.135
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BSMKTH-SOMVRPU-200.94
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BSMKTH-SUPRAJ-202.8
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-BSMKTH-YASHHOTL-200.139
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-ANJANRAM-200.104
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-AZEEMTWR-202.10
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-BINTRIF-200.98
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-CHBSPOLGR-202.9
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-DOLACHAM-200.106
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-KHADIRES-200.82
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-KUSHLTWR-200.127
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-MAHASWEE-200.141
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-MJHOSTL-200.113
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-NOORI-200.96
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-PETER-200.101
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-PGCOLLEG-201.250
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-CHNTLB-SHYAMNGR-200.95
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:04 BHIL-4-CHNTLB-YETUTWR-202.29
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ERAMZL-ANDRABNK-200.42
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ERAMZL-BHNUVIL-201.3
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ERAMZL-CHANDWNI-200.116
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ERAMZL-DURGACAS-202.41
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-ERAMZL-HARYMANS-202.48
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ERAMZL-INTECH-202.17
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ERAMZL-LUMBINRK-200.76
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-ERAMZL-NAVENNGR-200.12
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ERAMZL-PADMANGR-201.10
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-ERAMZL-SHARADHA-200.11
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ERAMZL-SHIVGNG-200.57
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:07 BHIL-4-ERAMZL-SURYPTS-200.105
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-ERAMZL-VRCOLONY-202.13
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:04 BHIL-4-INDIAN-202.60
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-AHEED-200.115
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-BALAMANI-200.125
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-BDGNESH-200.86
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-MORESUPR-200.132
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-MSMAKTHA-200.88
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-OLDCIBQT-200.121
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-POORNA-200.108
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-RAJNGR-200.122
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-RAVIBHAR-200.97
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-SHISAIAP-201.249
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-SRISAIRE-200.109
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-SUPERNET-200.140
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-KHRTBD-TJENCLVE-200.93
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MALLPL-BARTHGND-200.220
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MALLPL-BHARAAPT-202.39
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MALLPL-GATLAMAZ-202.15
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MALLPL-KABABISH-200.211
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MALLPL-MIRSIFLI-200.226
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MALLPL-NADEEM-200.221
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MALLPL-PRINHOTL-200.251
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MALLPL-ROCK-200.234
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MALLPL-SAFCO-200.213
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MALLPL-SUHNRESD-200.218
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MLACLY-AJAZ-202.37
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-BALAJI-200.182
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-DURGTEMP-200.190
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-GOLDSAND-200.157
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-LAKSNIVA-200.179
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-LOTUPOND-201.246
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MLACLY-MLACLY-200.181
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MLACLY-NIRMLAND-202.55
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-PAVANRES-200.162
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-PHOTOCLY-200.192
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MLACLY-PLOTNO47-202.5
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-PRIME-200.197
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-ROCKROOF-201.162
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MLACLY-SPEAKHSE-200.200
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-SRAVANTH-200.170
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-SUMEETH-202.12
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-SUSHHITE-200.159
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLACLY-VEDANT1-200.187
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-MLACLY-VEDNTVIL-200.178
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-MLLPLY-AKHSPTAL-201.208
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-BABATEMP-200.100
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-BLUEMOON-200.126
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-DWRKPURI-200.81
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-GVKPOP-200.114
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-PANJAG-LAXMIPTI-202.1
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-MILLBLOC-202.3
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-MLAAPTS-200.102
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-4-PANJAG-MODELHOU-202.34
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-MSREDAPT-200.90
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-NIMS-200.91
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-POLICSTN-201.2
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-RAJESTWR-202.2
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-RASPOLY-200.80
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-SBI-200.123
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-PANJAG-SSDHOSTEL-201.4
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-RDHILL-FEDRATIN-200.249
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-REDHIL-ARUN-200.206
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-REDHIL-BHARAT-200.224
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-REDHIL-BLCKCROS-200.243
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-REDHIL-HAMEDALI-200.217
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-REDHIL-HEENA-200.230
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:08 BHIL-4-REDHIL-RAVINATH-201.211
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-REDHIL-REDHILS-201.205
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-REDHIL-UMBRELLA-201.209
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SHNTNG-FRTUNHGT-200.204
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SHTNGR-PSNGR-201.241
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SHTN-MAPARRCY-201.212
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-ARCHAPTS-200.84
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-BINDHAPT-200.107
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-CIVILSU-200.134
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-COSMOPOl-201.245
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-DURGNGR-200.128
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-DWRKPTS-200.137
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-JAFFABAG-200.119
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-JOYLUKS-200.130
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-KAPALINE-201.248
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-MAATV-200.118
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-PAVPLAZA-200.143
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-POLCQRTS-200.112
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-RAJBHAVN-200.85
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-REDROSE-200.117
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-RSSTOWER-200.120
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-SHAPCOMP-202.4
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-SIRIMALE-200.110
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-SOMAJI-VILMARCO-200.133
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-ALI-200.246
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-BHRDWJ-201.6
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-CSTEHILS-200.225
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-HARMONY-202.11
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-INDINBNK-201.207
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-JAYA-200.237
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:06 BHIL-4-VJNGCL-NETWORK-202.52
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-4-VJNGCL-PANJA-200.231
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-PARTHA-200.238
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-PREMIUM-202.53
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-RMNREDDY-200.202
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-SHNINGR1-200.203
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-URRAO-200.212
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCL-VIJYNGR-200.219
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-4-VJNGCY-VIKAS-201.215
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-ANANDNAGAR-241.18
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-ANDHRA_BANK-241.97
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-AYUBHOME-1GIG-241.16
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-BADABAZAR-1G-241.65
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:02 BHIL-BAP-BANJARAHILLS-241.15
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-BRIJESHHOME-241.12
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-DECCAN-GIG-241.58
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-BAP-DURGATEMPLE-HI-241.73
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-DWARAKAPURI-241.13
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-BAP-GANESHTEMPLE-GIG-241.71
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-GEPON-OLT-241.14
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-HILLTOP-1GIG-241.67
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-BAP-JAFFERALIBAGH-1GIG-241.69
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-JOURNALIST_COLONY-241.98
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-MQNEST-1GIG-241.68
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-MSMAKTHA-GIG-241.61
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-NANDINAGAR-241.17
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-NANDINAGAR-LL-241.43
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-RAMLEELA-1G-241.63
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-RD#12-GIG-241.27
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-BAP-RD#13-GIG-H-241.70
drwxrwxr-x 2 nagios nagios 4096 Jun 24 16:52 BHIL-BAP-SAPHIRE-241.77
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-SHANTHINAGR-1G-241.64
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-SHYAMNAGAR-GIG-241.21
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-SRISAIRES-GIG-23
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-SVLAHARI-1GIG-241.66
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-THABANDA-241.74
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-BAP-UBICOLONY-241.79
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-BAP-VENUEBANJARA-241.76
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BAP-VIJAYNAGAR-241.20
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BRSW-AYUBHOME-241.11
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BRSW-BANJARAHILLS-241.10
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-BRSW-SOMAJIGUDA-HI-241.60
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BRSW-SRIRAMNAGAR-241.99
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BRSW-STORES-241.90
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 BHIL-BRSW-VEDANTHVILLA-HI-241.75
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-BRSW-VIJAYHILLS-1G-241.19
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-CHURCH-GIG-241.62
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-LLBONU-RD#12-241.38
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-PARKINGOFFICE-241.96
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-SRISAIRES-LL-TRUNK-36
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-ASIFNAGAR-GIG-44
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-AVANI-GIG-48
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-AYUB-LL-39
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-BEAMPARKING-LL-34
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-BHARAT-GROUND-GIG-24
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-BHOIGUDAKAM-GIGA-28
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-BRANCH-LL-32
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-BRIJESH-LL-41
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-BSMAKTHA-GIGA-25
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-DWARAKAPURI-LL-40
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-GARDENTWRS-GIG-29
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-KHAJANAAGAR-GIG-56
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-MITHILANAGAR-GIG-51
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-PASHACOURT-GIG-46
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-RAZIYUDDIN-GIG-50
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-RDNO13-LL-37
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-ROCKETGROUND-GIG-55
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-SHEETAL-GIG-49
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-SHYAMNAGAR-LL-30
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-SOMAJIGUDA-GIG-22
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-SOMAJIGUDA-LL-42
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-SRIRAMNAGAR-GIG-31
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-STORESBUILD-GIG-54
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-TEJA-GIG2-241.59
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-TREETOP-33
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-TREETOP-GIG-47
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-VEDANTHVILLA-GIG-45
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-VIJAYAHILLS-LL-43
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BHIL-TRNK-WAJIDHOUSE-GIG-26
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 BNJH-4-SOMAJI-VINEETH-200.142
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 CANNA2
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 CBLOCK
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 CHAMBER
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 DWARKA
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 EBONY
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 EMRALD
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 FLORA-NEW
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 GREENSTREET
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 HASANTOWER
drwxrwxr-x 2 nagios nagios 4096 Jun 18 17:59 HES
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 HILPARK
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 HINAS.1.223
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 IDC1-NR1-SWT-BHILDSBN-241.9
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 KENNA
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 KRISHNAAPT
drwxrwxr-x 2 nagios nagios 4096 Jun 18 17:59 KUSUMBASIR-FUEL
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 localhost
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 MADHU
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 MAJOR
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 Managed_9_Ports_100M_Switch
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 MARVEL-NEW
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 MIRASIF
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 MIRASIF-2
drwxrwxr-x 2 nagios nagios 4096 Jun 18 03:51 MYHOME
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 NAFEES
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 nafees2
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 NARSIMHAKRUPA
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 new
drwxrwxr-x 2 nagios nagios 12288 Jun 26 00:09 NEW-MANAGEMENT-SWITCH
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 NOBLE
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 PARIMALA
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 RAJNIKANTH
drwxrwxr-x 2 nagios nagios 4096 Jun 18 17:59 RIAH
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 ROSE
drwxrwxr-x 2 nagios nagios 4096 Jun 18 03:51 ROSEENCLAVE
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 RUPA
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 shanthi
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 subarao
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 SURYA
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 Sw1.220
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 Sw1.221
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 Sw1.222
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 SW.new
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 SW-NEW
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 SW-UMA-1.230
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 VIDI
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:14 VIEW
drwxrwxr-x 2 nagios nagios 4096 Jun 18 18:00 VIJAYA
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-ANDNGR-241.18-V-SRINIVAS-200.15
drwxrwxr-x 2 nagios nagios 4096 Jun 18 04:17 Z1-BAP-BADAMASJID-241.78
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-BAP-THABANDA-241.74-WAHEED-202.21
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-BH12-H-12SQUARE-200.154
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-BH14-V-CANARA_BANK-201.8
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-BH14-V-UNION_BANK-201.7
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-BSMAKTHA-241.25-V-BLUEDIAMOND
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-BSMAKTHA-241.25-V-SUZUKI-200.131
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-MITHILANAGAR-241-51-V-NBTNAGAR-200.189
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-MITHILANGR-241.51-V-MITHILANAGAR-2-200.194
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-MLAC-V-RAMANGUPTA-200.155
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-RD-13-241.27-V-NTRHOME-200.188
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-SHYAMNGR-241.21-H-SVLAHARI-200.92
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-SHYAMNGR-241.21-V-SRT-200.124
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-SMGD-3-PASHACOURT-200.87
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-STORESBUILD-241.54-28V-SITARAMANJANEYA-201.11
drwxrwxr-x 2 nagios nagios 4096 Jun 26 00:09 Z1-VEDANTHVILL-241.45-V-SHYAMVIJAY-200.177
this is the latest output of
Graphs are also not available for any of the hosts or services
in case would you like to ssh the server ?
Post
by slansing » Tue Jun 25, 2013 1:59 pm
Lets try the following again, if you did completely stop NPCD and kill it's processes and then restarted it, there should be no reason why you see that TIMEOUT error, unless you are seeing the old logs.. you did truly verify that they are the current time correct? That was not answered:
ps -aef | grep npcd
service npcd stop
killall -9 npcd
service npcd start
sarfarosh
Post
by sarfarosh » Tue Jun 25, 2013 2:07 pm
slansing wrote: Lets try the following again, if you did completely stop NPCD and kill it's processes and then restarted it, there should be no reason why you see that TIMEOUT error, unless you are seeing the old logs.. you did truly verify that they are the current time correct? That was not answered:
ps -aef | grep npcd
service npcd stop
killall -9 npcd
service npcd start
Slansing this is the last thing in mine perfdata.log with the time stamp 3 hours back of current time, log file didn't seems to have got updated from last 3 hours
below are the output of the commands
[root@nagios155 ~]# ps -aef | grep npcd
nagios 23305 1 0 00:10 ? 00:00:00 /usr/local/nagios/bin/npcd -d -f /usr/local/nagios/etc/pnp/npcd.cfg
root 31080 25968 0 00:33 pts/2 00:00:00 grep npcd
[root@nagios155 ~]# service npcd stop
NPCD Stopped.
[root@nagios155 ~]# killall -9 npcd
npcd: no process killed
root 32101 25968 0 00:33 pts/2 00:00:00 grep npcd
[root@nagios155 ~]# service npcd start
NPCD started.
[root@nagios155 ~]# date
Wed Jun 26 00:34:29 IST 2013
[root@nagios155 ~]#
Post
by slansing » Tue Jun 25, 2013 2:37 pm
Hmm, what is the output of:
ll /usr/local/nagios/var/spool/xidpe/
ll /usr/local/nagios/var/spool/checkresults/
Have you tried to integrate ramdisk at all? Or rrdcached?
sarfarosh
Post
by sarfarosh » Tue Jun 25, 2013 2:41 pm
slansing wrote:
Have you tried to integrate ramsidk at all? Or rrdcached?
have not got you
Below is the output
[root@nagios155 ~]# ll /usr/local/nagios/var/spool/xidpe/
total 0
[root@nagios155 ~]# ll /usr/local/nagios/var/spool/checkresults/
total 4
-rw------- 1 nagios nagios 458 May 18 14:26 c4RonoN
-rw------- 1 nagios nagios 0 May 18 14:26 cE9hmQY
-rw------- 1 nagios users 0 May 18 14:26 ch4ZZP3
-rw------- 1 nagios users 0 May 18 14:26 cij3ZUb
-rw------- 1 nagios users 0 May 18 14:26 co5wIYp
-rw------- 1 nagios users 0 May 18 14:26 csbOjdE
-rw------- 1 nagios users 0 May 18 14:26 cT7GtbB
-rw------- 1 nagios users 0 May 18 14:26 czx3sy0
[root@nagios155 ~]#
would you like to check yourself by SShing the nagios server ?
abrist
Red Shirt
Posts: 8334 Joined: Thu Nov 15, 2012 1:20 pm
Post
by abrist » Wed Jun 26, 2013 9:54 am
Then you most likely have solved the perf data issues. Are you still having issues with the reported bandwidth usages of switch/router ports?
Come to the
Dark Side .
