Monitoring nagios on a other network
This support forum board is for questions relating to Nagios Fusion.
solvisoft
Re: Monitoring nagios on a other network
Post by solvisoft »
i tried looking up "/usr/local/nagiosfusion/var/components/recentalertsfail.log" but i can't find any log in this directory.
The date for last update on this image was several days old when posted
http://support.nagios.com/forum/viewtop ... 327#p59439
Can we tail the cron log to make sure the poller.php cron is running
tail /var/log/cron
Also, can you try to run it manually and report any errant output
php /usr/local/nagiosfusion/cro/poller.php
solvisoft
Post by solvisoft »
i tried searching for the file but the location and file does not exist.
Sorry, it should have been
php /usr/local/nagiosfusion/cron/poller.php
solvisoft
Post by solvisoft »
i have the output of the command
except i have a problem that the nagios core now gets Server Timeout in the server credentials screen.
i have the error message Server Timeout in the Nagios Fusion Server Credentials. > Issue found! changed back to port 80 then it says OK
Server Address = ServerIP
Server Type = Nagios Core
Authentication = HTTP Basic
Public url = http://ServerIP/nagios3/ > i actually want http://ServerIP:87/nagios3/
Internal url = http://ServerIP/nagios3/ > i actually want http://ServerIP:87/nagios3/
is it possible to let the fusion and core check on port 87 instead of 80 ?
i know that i can change the port on Nagios Core with
sudo nano /etc/apache2/ports.conf
is there also some command for Fusion ?
Reason: Do not make double posts, just edit your previous post.
Post by slansing »
Ah excellent! Were you trying to check against 443 or something? What issues are you still having?
solvisoft
Post by solvisoft »
we used the default port in Nagios core (80) then the Fusion can monitor this machine.
is there a way to change the port back to 87 and get the Fusion to monitor this ?
for security reasons we want to change to a different port and NOT port 80
Post by slansing »
When you try to connect to the XI web interface via that port is it functioning?
solvisoft
Post by solvisoft »
i can connect to the Nagios Core if i set the Port to 87
i have to go to http:\\serverip:87\nagios3
nagios3 runs on a RaspberryPi
Nagios Fusion runs on a ESXI machine.
Do you get "Auth Check" = OK (Configure->Server Credentials), when you enter your credentials, and click on "Update Settings" (provided you've set up the "Public URL" and "Internal URL" as "http://serverip:87/nagios3/")?
