issue with Windows Agent
Re: issue with Windows Agent
Can you send a copy of your nsclient.log file? It should be in your installation directory. Also, what version of Windows is this, and have you verified it is NOT 64-bit?
is there any permissions to setup?
in this thread
http://nsclient.org/nscp/discussion/message/2073
it mentioned that it was a permissions issue...
in this thread
it is MS Windows Server 2003 R2
I verified it is 32 bit, I got it working on another identical machine...
here is the log entry
2013-09-11 15:24:55: message:modules\FileLogger\FileLogger.cpp:86: Starting to log for: NSClient++ - 0.3.9.327 2011-08-16
2013-09-11 15:24:55: debug:CACHENSClient++.cpp:557: Attempting to start NSCLient++ - 0.3.9.327 2011-08-16
2013-09-11 15:24:55: message:CACHEmodules\FileLogger\FileLogger.cpp:87: Log path is: C:\Program Files\NSClient++\\nsclient.log
2013-09-11 15:24:55: error:CACHEmodules\CheckSystem\PDHCollector.cpp:140: Failed to open performance counters: LoadLibrary for PDH failed: 126: The specified module could not be found.
2013-09-11 15:24:55: error:CACHEmodules\CheckSystem\PDHCollector.cpp:185: Failed to open performance counters: LoadLibrary for PDH failed: 126: The specified module could not be found.
2013-09-11 15:24:55: error:modules\CheckSystem\PDHCollector.cpp:219: No performance counters were found we will not wait for the end instead...
2013-09-11 15:27:17: error:modules\CheckSystem\PDHCollector.cpp:271: Failed to get CPU value: <UN ATTACHED>: No value has been collected yet
2013-09-11 15:40:07: message:modules\FileLogger\FileLogger.cpp:86: Starting to log for: NSClient++ - 0.3.9.327 2011-08-16
2013-09-11 15:40:07: debug:CACHENSClient++.cpp:557: Attempting to start NSCLient++ - 0.3.9.327 2011-08-16
2013-09-11 15:40:07: message:CACHEmodules\FileLogger\FileLogger.cpp:87: Log path is: C:\Program Files\NSClient++\\nsclient.log
2013-09-11 15:40:07: error:CACHEmodules\CheckSystem\PDHCollector.cpp:140: Failed to open performance counters: LoadLibrary for PDH failed: 126: The specified module could not be found.
2013-09-11 15:40:07: error:CACHEmodules\CheckSystem\PDHCollector.cpp:185: Failed to open performance counters: LoadLibrary for PDH failed: 126: The specified module could not be found.
2013-09-11 15:40:07: error:modules\CheckSystem\PDHCollector.cpp:219: No performance counters were found we will not wait for the end instead...
2013-09-11 15:41:31: error:modules\CheckSystem\PDHCollector.cpp:271: Failed to get CPU value: <UN ATTACHED>: No value has been collected yet
2013-09-11 15:42:31: error:modules\CheckSystem\PDHCollector.cpp:271: Failed to get CPU value: <UN ATTACHED>: No value has been collected yet
2013-09-11 15:42:35: error:modules\CheckSystem\PDHCollector.cpp:334: Failed to get MEM_CMT value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:34:25: error:modules\CheckSystem\PDHCollector.cpp:271: Failed to get CPU value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:35:25: error:modules\CheckSystem\PDHCollector.cpp:271: Failed to get CPU value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:35:28: error:modules\CheckSystem\PDHCollector.cpp:334: Failed to get MEM_CMT value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:36:25: error:modules\CheckSystem\PDHCollector.cpp:271: Failed to get CPU value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:36:28: error:modules\CheckSystem\PDHCollector.cpp:334: Failed to get MEM_CMT value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:36:31: error:modules\CheckSystem\PDHCollector.cpp:293: Failed to get UPTIME value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:37:25: error:modules\CheckSystem\PDHCollector.cpp:271: Failed to get CPU value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:37:28: error:modules\CheckSystem\PDHCollector.cpp:334: Failed to get MEM_CMT value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:37:31: error:modules\CheckSystem\PDHCollector.cpp:293: Failed to get UPTIME value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:38:25: error:modules\CheckSystem\PDHCollector.cpp:271: Failed to get CPU value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:38:28: error:modules\CheckSystem\PDHCollector.cpp:334: Failed to get MEM_CMT value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:38:31: error:modules\CheckSystem\PDHCollector.cpp:293: Failed to get UPTIME value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:39:28: error:modules\CheckSystem\PDHCollector.cpp:334: Failed to get MEM_CMT value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:39:31: error:modules\CheckSystem\PDHCollector.cpp:293: Failed to get UPTIME value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:39:45: message:modules\FileLogger\FileLogger.cpp:86: Starting to log for: NSClient++ - 0.3.9.327 2011-08-16
2013-09-12 09:39:45: debug:CACHENSClient++.cpp:557: Attempting to start NSCLient++ - 0.3.9.327 2011-08-16
2013-09-12 09:39:45: message:CACHEmodules\FileLogger\FileLogger.cpp:87: Log path is: C:\Program Files\NSClient++\\nsclient.log
2013-09-12 09:39:45: error:CACHEmodules\CheckSystem\PDHCollector.cpp:140: Failed to open performance counters: LoadLibrary for PDH failed: 126: The specified module could not be found.
2013-09-12 09:39:45: error:CACHEmodules\CheckSystem\PDHCollector.cpp:185: Failed to open performance counters: LoadLibrary for PDH failed: 126: The specified module could not be found.
2013-09-12 09:39:45: error:modules\CheckSystem\PDHCollector.cpp:219: No performance counters were found we will not wait for the end instead...
2013-09-12 09:40:17: error:modules\CheckSystem\PDHCollector.cpp:271: Failed to get CPU value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:40:22: error:modules\CheckSystem\PDHCollector.cpp:334: Failed to get MEM_CMT value: <UN ATTACHED>: No value has been collected yet
2013-09-12 09:40:27: error:modules\CheckSystem\PDHCollector.cpp:293: Failed to get UPTIME value: <UN ATTACHED>: No value has been collected yet
I tried resetting my counters 'lodctr /R' and install the last stable version agent, but same results
sreinhardt
- -fno-stack-protector
Is your nsclient user a part of the performance counter group?
no, I have Performance Log Users and Performance Monitor Users,
I have another server that replicates this server, they both have the same setup....
the other server does work, and I'm using the Local System Account to run nsclient
Actually, run the following from the command prompt:
http://support.microsoft.com/kb/300956
Open the Performance Monitor and re-add the counters you need. Lastly, restart the nsclient++ service.
Let us know if this helped.
cd\windows\system32
lodctr /ROpen the Performance Monitor and re-add the counters you need. Lastly, restart the nsclient++ service.
