CentOS errors
Re: CentOS errors
Post by slansing »
check_snmp is included with 1.5. Did you compile properly? Did you see any errors?
MPIvan
Re: CentOS errors
Post by MPIvan »
I follow the instruction "Installing Nagios Core From Source" no errors was found ... should i do it again ?
abrist
Red Shirt
Re: CentOS errors
Post by abrist »
Download and build an older version of the plugins. Once built, only copy over those plugins that you are missing into your libexec folder.
Re: CentOS errors
Post by slansing »
Do you have locate installed on your system?:
yum install mlocate
updatedb
locate check_snmp
If you do not find it, you can re-compile, just make sure you follow the commands completely, including configure, make, make all.
MPIvan
Re: CentOS errors
Post by MPIvan »
So i download the last version of the plugins and i follow the "Installing Nagios Core From Source" and i execute the following commands ....
./configure --with-nagios-user=nagios --with-nagios-group=nagios
make
make install
chkconfig --add nagios
chkconfig --level 35 nagios on
chkconfig --add httpd
chkconfig --level 35 httpd on
after restart the nagios i have this error:
Whoops!
Error: Could not read host and service status information!
The most common cause of this error message (especially for new users), is the fact that Nagios is not actually running. If Nagios is indeed not running, this is a normal error message. It simply indicates that the CGIs could not obtain the current status of hosts and services that are being monitored. If you've just installed things, make sure you read the documentation on starting Nagios.
Some other things you should check in order to resolve this error include:
Check the Nagios log file for messages relating to startup or status data errors.
Always verify configuration options using the -v command-line option before starting or restarting Nagios!
Make sure you read the documentation on installing, configuring and running Nagios thoroughly before continuing. If all else fails, try sending a message to one of the mailing lists. More information can be found at http://www.nagios.org.
Re: CentOS errors
Post by slansing »
Was this verified?
MPIvan
Re: CentOS errors
Post by MPIvan »
Yes nagios is running
Re: CentOS errors
Post by slansing »
Hmm, can you run the following:
service nagios stop
killall -9 nagios
service nagios start
Do you still receive the error? If so please run and show the output of:
ll -la /usr/local/nagios/sbin/
MPIvan
Re: CentOS errors
Post by MPIvan »
Here it is the output
[root@mpnagios ~]# service nagios stop
nagios is stopped
[root@mpnagios ~]# killall -9 nagios
nagios: no process killed
[root@mpnagios ~]# service nagios start
nagios is stopped
Nagios Core 4.0.1
Last Modified: 10-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Checked 12 services.
Warning: Host 'Router001' has no default contacts or contactgroups defined!
Checked 3 hosts.
Checked 3 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 25 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 3 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 1
Total Errors: 0
Object precache file created:
/usr/local/nagios/var/objects.precache
[root@mpnagios ~]# ll -la /usr/local/nagios/sbin/
total 4024
drwxrwxr-x. 2 nagios nagios 4096 Oct 22 18:58 .
drwxr-xr-x. 8 root root 4096 Oct 22 18:59 ..
-rwxrwxr-x. 1 nagios nagios 288008 Oct 22 18:58 avail.cgi
-rwxrwxr-x. 1 nagios nagios 285064 Oct 22 18:58 cmd.cgi
-rwxrwxr-x. 1 nagios nagios 255176 Oct 22 18:58 config.cgi
-rwxrwxr-x. 1 nagios nagios 300264 Oct 22 18:58 extinfo.cgi
-rwxrwxr-x. 1 nagios nagios 255432 Oct 22 18:58 histogram.cgi
-rwxrwxr-x. 1 nagios nagios 230632 Oct 22 18:58 history.cgi
-rwxrwxr-x. 1 nagios nagios 230600 Oct 22 18:58 notifications.cgi
-rwxrwxr-x. 1 nagios nagios 226472 Oct 22 18:58 outages.cgi
-rwxrwxr-x. 1 nagios nagios 226760 Oct 22 18:58 showlog.cgi
-rwxrwxr-x. 1 nagios nagios 296200 Oct 22 18:58 status.cgi
-rwxrwxr-x. 1 nagios nagios 248712 Oct 22 18:58 statusmap.cgi
-rwxrwxr-x. 1 nagios nagios 242952 Oct 22 18:58 statuswml.cgi
-rwxrwxr-x. 1 nagios nagios 230664 Oct 22 18:58 statuswrl.cgi
-rwxrwxr-x. 1 nagios nagios 251144 Oct 22 18:58 summary.cgi
-rwxrwxr-x. 1 nagios nagios 242952 Oct 22 18:58 tac.cgi
-rwxrwxr-x. 1 nagios nagios 259528 Oct 22 18:58 trends.cgi
[root@mpnagios ~]#
still the same error
abrist
Red Shirt
Re: CentOS errors
Post by abrist »
Which error is the same? It looks like nagios restarted successfully in your last post.
