CentOS errors
MPIvan
CentOS errors
Post by MPIvan »
Hi all,
I start installing Nagios on CentOS, so everything went ok, but i have problems with the service, check_snmp, when i try to execute i have the folowing error
[root@mpnagios libexec]# ./check_snmp -h
./check_snmp: /lib64/libc.so.6: version `GLIBC_2.14' not found (required by ./check_snmp)
any suggestion ?
schweet
Re: CentOS errors
Post by schweet »
Your missing libs.
#yum install glibc
Not sure about the other errors.
abrist
Red Shirt
Re: CentOS errors
Post by abrist »
That take care of it MPIvan?
MPIvan
Re: CentOS errors
Post by MPIvan »
No not helping ...
[root@mpnagios ~]# yum install glibc
Loaded plugins: fastestmirror, security
Loading mirror speeds from cached hostfile
* base: mirror.cabletel.com.mk
* extras: mirror.cabletel.com.mk
* updates: mirror.cabletel.com.mk
base | 3.7 kB 00:00
extras | 3.4 kB 00:00
updates | 3.4 kB 00:00
updates/primary_db | 5.0 MB 00:00
Setting up Install Process
Package glibc-2.12-1.107.el6_4.5.x86_64 already installed and latest version
Nothing to do
[root@mpnagios ~]#
Re: CentOS errors
Post by slansing »
It looks like you are running CentOS 6.4 correct? The current version of GLIBC is 2.18 but yum is not updating you to that for whatever reason.
MPIvan
Re: CentOS errors
Post by MPIvan »
Yes im running CentOS 6.4 ... and as i can see im running 2.12 version but cant update to 2.18 or newer. So i guess the issue is that ...
i need uptime status of a router, before i installed Nagios on CentOS iv use "check_snmp" on Ubuntu .. because i start all over again but on CentOS im just using the files .cfg and i have to make this work or i will have too much work to go to change all this to work with other script plugin or what ever
[root@mpnagios ~]# /lib/libc.so.6
GNU C Library stable release version 2.12, by Roland McGrath et al.
Copyright (C) 2010 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
Compiled by GNU CC version 4.4.7 20120313 (Red Hat 4.4.7-3).
Compiled on a Linux 2.6.32 system on 2013-10-14.
Available extensions:
The C stubs add-on version 2.1.2.
crypt add-on version 2.1 by Michael Glad and others
GNU Libidn by Simon Josefsson
Native POSIX Threads Library by Ulrich Drepper et al
BIND-8.2.3-T5B
RT using linux kernel aio
libc ABIs: UNIQUE IFUNC
For bug reporting instructions, please see:
<http://www.gnu.org/software/libc/bugs.html>.
[root@mpnagios ~]#
sreinhardt
-fno-stack-protector
Re: CentOS errors
Post by sreinhardt »
Was your check_snmp compiled on this cent system or the previous ubuntu system? There will be some changes and differences between systems, and binaries are not likely compatible between them due to version and location differences of files. I just wanted to validate that this was created on the cent system so that we are not debugging things that will not be there.
MPIvan
Re: CentOS errors
Post by MPIvan »
I thought of that but i wasn't sure if it could be that :) ... yes, before i installed Nagios on CentOS i make backup from Ubuntu, i take the files and plugins ( for files .fg i don't used them, because i start all over again ) but for the "check_snmp" i copy in the directory in CentOS and i try to use. But also the version of GLIBC is 2.12 and the newer is 2.18, so what should i looking now ? I use check_snmp for Uptime status.
sreinhardt
Re: CentOS errors
You should recompile ALL plugins for the new system. Unless they are scripts like python, bash, and perl, all compiled plugins will always need to be recompiled for a new OS or architecture. Until then, this and many other plugins will continue to fail as they are dynamically linked to files they depend on, that massively change between linux distros and versions.
MPIvan
Re: CentOS errors
Post by MPIvan »
When i install Nagios on CentOS i install nagios-plugins-1.5 ... but there i dont see the check_snmp .... so do i have to download older version of the plugins and installed ( recompile ) again or ?? can i just use or some how install just check_snmp ?
