OK, so you are attempting a reinstall of autoconf. can you list that directory? Does it maybe have just a ./config not ./configure?
OK, I guess we're confused at this point, didn't the which autoconf indicate that it was already installed? If so ./configure should be run in the directory containing the nagios source. If you are trying to reinstall autoconf, I hate to push you away, but I would suggest looking up how to build that for freebsd as it is out of the scope of our support.
